Power Steering is locked! Help.
Old Dec 13, 2008 | 11:49 AM
ZumnRx8's Avatar
RX8 & RX7 owner
Yesterday my power steering locked while i was going through a POLLO LOCO. I was in the middle of the drive through and i thought my car had turned off because my power steering locked but it didnt, my car was still on and the little Steering wheel light was on. Whats sup with that?? Its still on right now. Anoyone know why this would be? Funny thing is that yesterday i took my car into the dealer to get my taillamp replaced and the manager there also owns a fiirst GEN rx8 and i remember him at that time saying that his power steering had locked up also. So whats sup with this?
Old Dec 13, 2008 | 11:53 AM
EDZRIDE's Avatar
2005 White GT
Check the P/S connection.
Old Dec 13, 2008 | 12:11 PM
ZumnRx8's Avatar
RX8 & RX7 owner
where is that?? if not then monday i have to take it to the dealer, its a bitch to turn, will i mess up my car by driving it like this till monday?
ZumnRx8's Avatar
RX8 & RX7 owner
if anything i have warranty.
Old Dec 13, 2008 | 12:23 PM
alnielsen's Avatar
This has been answered many times on here.
The connectors for the power steering are below the air filter box. Remove the air box. Below the air box is a support tray. Remove the tray. Now you have access to the power steering connectors. There are 2.
Old Dec 13, 2008 | 01:10 PM
ZumnRx8's Avatar
RX8 & RX7 owner
f-n-****-man. thanks, im just gonna take it it on monday
Old Dec 13, 2008 | 02:42 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah the overflow from the coolant goes right down on the power steeering lines so if you overflow it could def mess stuff....if ur in warranty i'd take it there and not even worry about it
Old Dec 15, 2008 | 04:07 PM
ZumnRx8's Avatar
RX8 & RX7 owner
ok so i was suppose to take it today but i didnt, i have to reschedule for tomorrow, I dont know what it can be, i think its just a sensor because 1 out of 10 times the light went off and my power steering worked.
Old Dec 15, 2008 | 04:20 PM
dozer's Avatar
on his 3rd rx8
im your daddy now check your myspace
Old Dec 19, 2008 | 10:53 PM
Urban Legend's Avatar
Make Some Noise
I had the same power steering problem. The way I solved my problem was by accident. Change the car battery to a stronger voltage. Then drive as normal to see if the problem comes up again. Also rumor has it if you change the powering steering fluid to Lucas brand it's a good start... Reply back with some results. Catch you next time!
Old Dec 20, 2008 | 12:08 AM
max5roadster's Avatar
INDY RX8 CLUB - Officer
^Please tell me your joking?!?!?!?! If not, then you are hereby banned from giving advice in the tech forum!
Old Dec 20, 2008 | 01:04 AM
DOMINION's Avatar
I don't buy Kool-Aid
Lets see if this works lol
Turn your key to the on position. Turn the wheel all the way to the left then all the way to the right then back to center. See what happens.
Old Dec 20, 2008 | 03:37 PM
Make Some Noise
Ok guy since your so smart how about you put your 2 sense in this and solve this guys power steering problem. If you don't have an answer then what are you doing here then?
Old Dec 20, 2008 | 03:45 PM
Jon316G's Avatar
Grasshopper
I believe max5roadster was referring to your statement about power steering fluid... since we don't use fluid (power steering is electric).
I can answer here because I have solved my power steering issue by splicing the power and torque sensor harness wires above the radiator.
Old Dec 20, 2008 | 03:50 PM
SebtownRx8's Avatar
75shot55fueljets=GOBABYGO
He is saying why would you recommend something that you have not tried yourself and if you would of even tried to change the power steering fluid you'd realize its electric.......
Old Dec 20, 2008 | 06:45 PM
Make Some Noise
Talking
Wow than I guess Pepboys has lot of explaining to do...when they offered me a quote for $90 in the first place...
Thanks for the info....SebtownRx8
Old Dec 20, 2008 | 06:48 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
So much for Pepboys eh?
Tsurugi
Sep 7, 2015 08:27 PM
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
stickmantijuana
Sep 4, 2015 10:31 PM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
