View Poll Results: Which Exhaust?
B&B (vividracing.com)
9.68%
GReddy (rx8store.com)
22.58%
Rx8 store (sr8store.com)
16.13%
Other (Borla, etc)
16
51.61%
Voters: 31. You may not vote on this poll
Exhausts, exhausts and more exhausts...
Old Dec 8, 2003 | 07:48 PM
emack's Avatar
Ride It Like You Stole It
Exhausts, exhausts and more exhausts...............
We need to somehow put together a matrix of all the exhausts coming on to the market and rate them against certain criteria ie price, hp gains, sound (non rice!) and quality etc.
Anybody got any ideas how we can get all the information together?!
So far we have:
Borla
B&B
Greddy
HKS
JIC
Racing Beat (almost ready)
....and I'm sure I've missed some.
Old Dec 8, 2003 | 08:09 PM
mikeb's Avatar
100% Italian
spintech
magnaflow is soon
good idea though
Old Dec 8, 2003 | 08:40 PM
Dookie_Rx-8's Avatar
FourOneMuthaFcuknFive
yes i HATE having to compare sounds looking all over the forum
Old Dec 9, 2003 | 12:19 AM
Sin's Avatar
Sin
Magnaflows, I have them but they sound EXACTLY like the B&B.
Old Dec 9, 2003 | 04:58 AM
bobclevenger's Avatar
Re: Exhausts, exhausts and more exhausts...............
We also ought to establish a standard method for recording the sound clips. Inside the car, outside the car, how far away from the car if outside? Load (car would be in motion) or no load? I know how I did mine, but nobody else has said how they did theirs.
Old Dec 9, 2003 | 11:27 PM
rotarygod's Avatar
How about loudness? Get a standard test that uses a simple Radio Shack spl meter at a set distance straight behind the car. Do one test at idle and another at a different rpm. Obviously it would be louder if the car were under a load but any differences is db between each system would at least be evident.
Old Dec 9, 2003 | 11:37 PM
Jason's Avatar
RX7store.net
You guys worry way to much about the sound of the exhaust. There is not going to be much of a difference between any of the exhausts listed. They all have similar qualities. The big difference in sound will be when you add a midpipe or remove the cat.
Jason
Old Dec 9, 2003 | 11:51 PM
rotarygod's Avatar
Some of those systems are very different from each other. So what you are saying is that if I were to install a fully baffled quiet muffler on one car and a pair of straight through unbaffled loud mufflers on another car, the sound won't be much different? Um, you need to go rethink that one a little bit. One muffler may sound more raspy then others. I've had so many different muffler combinations on my RX-7's through the years and the differences are night and day. This applies to any engine. If every aftermarket company comes out with the exact same product with a different name stamped on it, then your statement would be true.
Old Dec 10, 2003 | 09:10 AM
Jason's Avatar
RX7store.net
Most of these exhaust companies are going for more flow. True there will be a difference in sound depending on the mufflers used but not enough that you are going to be able tell much of a difference. I think most peoples concerns on here is that its not to loud, which non of them are until you remove the cat.
I have heard every exhaust system on an RX-7 and I cant tell much of a difference between them unless they are running a midpipe.
Jason
Old Dec 10, 2003 | 09:15 AM
XeRo's Avatar
Normality is Obscene
You've heard every exhaust system on an Rx-7???...hmmm...man i wish I had....
Old Dec 10, 2003 | 09:46 AM
racerdave's Avatar
F125er/Future RX-8er
Sound is too freaking subjective, and db tests don't tell all. So I don't think that'd be of any use.
BUT... there should be a sticky thread on Exhausts, and the only info posted there should be Type, dyno numbers and sound impressions.
NO posts like, "This exhaust rocks!" Just legit dyno charts for each exhaust.
Does that seem like a good idea?
See this board for an example...
http://www.is300.net/modules.php?nam...=viewforum&f=2
Just look at all the stickies there, why they are there and the info in them.
That way people wouldn't have to search up and down (the sticky part), plus it would be a no-nonsense post with just info about the exhausts and dyno numbers... no bickering or anything.
BUT... it would require a moderator to manage it to make sure it doesn't drift off mission.
Thoughts?
Old Dec 10, 2003 | 09:57 AM
Gord96BRG's Avatar
Thoughts?
Brilliant idea. We're already seeing lots of reviews here for intakes and exhausts, and (for example) not a single customer review of an intake has a dyno chart. They're all just "This intake sounds awesome, and my butt dyno tells me it must be faster". Those are not much help, frankly.
Regards,
Gordon
Old Dec 10, 2003 | 12:13 PM
slavearm's Avatar
Boost Junkie
My midpipe will be here shortly (right Jason?). I'll record some sound bytes stock and then with the midpipe, and then when the racing beat exhaust comes in, i'll record it with the stock muffy and then the racing beat.
Slavearm
Old Dec 10, 2003 | 02:08 PM
mikeb's Avatar
100% Italian
the racing beat exhuast isn't avaiable yet is it ?
Old Dec 10, 2003 | 02:23 PM
donald121's Avatar
I wanna get either Greddy or Borla. It would be nice if there's a dyno result for Greddy.
Old Dec 10, 2003 | 02:25 PM
Good idea, and I would add that it ought to be two stickies: one for street-lagal exhausts and another for off-road exhausts. It's silly to compare a catless system with a cat-back system.
Old Dec 10, 2003 | 05:39 PM
Omicron's Avatar
Ok, so if someone puts this all together in a thread, we'll see if we can get it stickied. Any volunteers?
Old Dec 10, 2003 | 08:34 PM
E-mail me at bob@bobclevenger.com and tell me what I'd have to do?
Old Dec 10, 2003 | 10:44 PM
Jason's Avatar
RX7store.net
I will make it a sticky as soon as we get the info.
Jason
Old Dec 11, 2003 | 03:52 AM
the B&B exhaust makes more power than the Borla...check the dyno sheets elsewhere on this forum...if im not mistaken the borla pipes (not exhaust tips) are around 3 inches or so?? and the B&B pipes are 2 1/2...thats where the loss in power is made...
Old Dec 11, 2003 | 12:11 PM
Jhouse's Avatar
more flow equals more noise period. regardless of what the noise is the big *** tips in the back will still make my car an even bigger target for the damn riceroni police.
Old Dec 11, 2003 | 12:39 PM
mikeb's Avatar
100% Italian
the ricearoni police suck and they are everywhere
Old Dec 11, 2003 | 01:29 PM
success07's Avatar
I'm Kind of a Big Deal
'ricearoni police' - that is hilarious!
Xdeed - Question for you - because the pipes are bigger on the borla than on the b&b there is less power in the borla exhaust?
Does this have to do with b&b allowing more back pressure due to the smaller pipe?
Old Dec 11, 2003 | 03:55 PM
Omicron's Avatar
Email is on the way, Bob.
Old Dec 11, 2003 | 06:59 PM
Probably has to do with the B&B keeping the velocity of the exhaust gases high enough so that their inertia helps pull them out of the engine -- a scavenging effect.
