Radar detector wiring help
Old Dec 10, 2008 | 09:18 AM
risky business's Avatar
IRC Founder
hey guys my problem is i have a cobra radar detector (i know, not the best) and a monster ipod hookup and both require the cigarette lighter but i only have 1. is there an easy'ish way to hardwire either of these 2 devices or maybe both?
Old Dec 10, 2008 | 09:41 AM
ShinkaTeen's Avatar
space reserved for shirt
i beleive there a way to hook up the radar detector to your top console (where your map lights are).
but i for one have no experiance with radar detectors. :/.
but i think there i DIY on here for it.
Old Dec 10, 2008 | 09:49 AM
StealthTL's Avatar
There is another power point (lighter) in the center compartment.
S
ShinkaTeen's Avatar
^^^ o thats right i forgot about that one.
Old Dec 10, 2008 | 10:45 AM
Silver06's Avatar
Zoom Zoom....
Risky Business.
This isn't talked about very often, but I have a 5 minute DIY for hardwiring a radar detector / navi / whatever. Cost is less than $10.
1. buy a "mini add-a fuse" from an auto parts store.
2. plug the add a fuse into position #1 in the fuse panel on the driver's side footwell. There is a bolt for ground just above the fuse panel, behind the lower plastic.
3. place the original 15A fuse into the add a fuse, and use a 1A fuse (comes with the add a fuse) for the new circuit.
4. wire the detector. Place wire under the rubber moulding up to the white plastic "A" pillar cover; under the pillar cover, and under the front of the headliner to where you want the detector. (I have my detector just to the (driver's) right of the rearview mirror - the pass. sunvisor still works).
5. Done. The wire is completely hidden.
6. Removal in future would take about 60 seconds.
My Valentine One uses regular telephone wire as it's power cable. A dollar store has 10' sections with plugs on each end.
Or, you can follow any of the DIY's where you can remove the sunglass holder / map lights and tap those wires....
Attached Thumbnails Radar detector wiring help-21wamu2jhsl._sl500_aa250_.jpg
Last edited by Silver06; Dec 10, 2008 at 10:49 AM. Reason: IMG tags aren't working... ???
Old Dec 10, 2008 | 12:15 PM
Never fear, Jedi is here!!
http://rotaryinsider.com/rx8-60.html
Old Dec 10, 2008 | 01:20 PM
IRC Founder
wow, thanks for all the replies!
Old Dec 10, 2008 | 01:34 PM
IRC Founder
thanks again, you guys are awesome!
Old Dec 10, 2008 | 04:21 PM
where is your RD mounted?
tjohnmeyer
Sep 28, 2017 05:03 PM
Danield97
Sep 30, 2015 05:59 PM
Quiggs321
Sep 30, 2015 05:34 PM
jer2911
Sep 29, 2015 06:37 PM
Learners_Permit
Sep 27, 2015 07:38 PM
