2nd failure on my '06 w'35K miles in a week!
Old Dec 4, 2008 | 11:57 AM
ShottsCruisers's Avatar
Rx7 and now Rx8
1. Simply changed batteries and the thing wouldn't start...it had to be towed. The relay on the starter went bad...it was fixed and it started up!
2. 5-days later...the battery light is on. At idle and close to idle there's a roughness and you can here low frequency popping (like a misfire). Now the idle speed is wierd as well. After letting off the gas the idle goes to about 1100RPM, then to 900 then up to 1000 and after a bit it'll go to normal. Drive-wise/power-wise...feels normal. Got power!
SO NOW WHAT'S WRONG?
Old Dec 4, 2008 | 12:13 PM
Neutral switch maybe ?
and it sounds like your alternator is bad.
Old Dec 4, 2008 | 12:18 PM
Rx7 and now Rx8
Wow...ya think that could cause the misfire/idle deal?
Old Dec 4, 2008 | 12:23 PM
04RX8man's Avatar
Rotary Powered Countryboy
I also would say check the alternator(which they should have check while fixing the starter but prob did not)
Old Dec 4, 2008 | 12:26 PM
if the alternator is not functioning, dont expect your car will function.
The problem here is that its hard to test Alternator. Sometimes when you test them under certain condition, it seems to be able to put out the right power (in our case its about 14.4 volt of power). but when u put it back on the car and run it with wires attached. U see something much lower than 14.x
So Its hard to tell. U have to monitor it.
Ugafan97
SE For Sale/Wanted
Apr 28, 2016 03:35 PM
atmd
Aug 19, 2015 12:43 PM
GracefulShanks
Aug 18, 2015 11:40 AM
dbarber
Jul 25, 2015 01:34 PM
mazdaverx7
Jul 21, 2015 07:31 PM
