ScanGauge II Xgauge Working Codes List
Old Nov 25, 2008 | 04:43 PM
aerospacediver's Avatar
I've been searching everywhere and no one has put up a list of working Xgauge codes that have been tested for the Rx-8. Im going to start working on the basic codes from the website and hopefully some other owners will help out. I also read that some users are using the Subaru codes. Hope this helps everyone.
So far:
Horsepower works (dont know how accurate it is)
o2 Sensor Data from CANxxx list works (Bank 1 Sensor 2)
From the Ford CAN list Transmission Fluid Temp (Does not work)
Will add more when I have time to test them.
Old Nov 26, 2008 | 09:29 PM
Had the chance to try out a few more last night during my lunch break.
Ford CAN list:
Barometric Pressure
Fuel Level
Does Not Work
For the CANxxx list:
Short term fuel trim and long term fuel trim (Bank 1) Works!
Old Nov 26, 2008 | 09:34 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
There was a list.....let me go find it!
Old Nov 26, 2008 | 09:39 PM
Mazurfer's Avatar
Check in this thread!
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/scangaugeii-review-105834/
Takes awhile before it's starts getting talked about in earnest, but there is some good info in there and some links.
I swear there is another one........I just have to find it!
Old Nov 27, 2008 | 03:01 PM
Ok after endless reading through the thread posted above here is the info I found.
There is no oil temp sensor so that is out.
Another User posted that these worked with the 8
Average Speed Current Trip
TXD=71, RXF=8000000000000, RXD=0000
MTH=000000000000, NAM=AVS. Don't forget to SAVE.
Time to Empty
TXD=64, RXF=8000000000000, RXD=0000
MTH=000000000000, NAM=TTE. Don't forget to SAVE.
Distance to empty
TXD=44, RXF=8000000000000, RXD=0000
MTH=000000000000, NAM=DTE. Don't forget to SAVE.
Fuel remaining in tank
TXD=24, RXF=8000000000000, RXD=0000
MTH=000000000000, NAM=FRT. Don't forget to SAVE.
Fuel Used
TXD=14, RXF=8000000000000, RXD=0000
MTH=000000000000, NAM=FUS. Don't forget to SAVE.
Average Fuel economy
TXD=04, RXF=8000000000000, RXD=0000
MTH=000000000000, NAM=AFC. Don't forget to SAVE.
Time for todays trip
TXD=51, RXF=8000000000000, RXD=0000
MTH=000000000000, NAM=TDT. Don't forget to SAVE.
There was mention of an EGT gauge that would be allsum but no word yet on that.
Old Nov 27, 2008 | 03:03 PM
mysql's Avatar
Doppelgänger
You are saying the o2 sensor is working with canscan? what's the code for that?
I have short term fuel trim, long term fuel trim. hp one works but the numbers are worthless. I saw 400 hp the other day at partial throttle.
Old Nov 27, 2008 | 04:07 PM
Bank 1 sensor 2 under CANxxx
File Type: pdf
Old Nov 27, 2008 | 04:35 PM
paulmasoner's Avatar
Asshole for hire
So far:
from my toying with the Scangauge stuff a few months back....
1)like mysql said, HP will give you a useless inaccurate number.
2)the O2 sensor does display data, but its not in lambda or afr. it displays on a 0-100 scale(although you'll never see either extreme), and the scale is NOT linear.
I did quite a bit of reading into the SAE papers on the OBD/CAN protocols back then trying to find something like a simple multiplier i could add into the Xgauge to make it display something useful like lambda/afr, but being a non-linear scale it should be impossible to get something useful out of the scangauge for the O2 sensors
Old Nov 27, 2008 | 04:47 PM
mysql's Avatar
Doppelgänger
accessport can display proper afr numbers. You just mean that the xgauge won't do the math to show the proper info?
Old Nov 27, 2008 | 04:52 PM
Asshole for hire
exactly. the Xgauge math functions ONLY include addition, subtraction, multiply, and divide in the simplest of forms. So if you start with a non-linear output, there is no way to multiply, divide, add, or subtract to reach a linear output
Hymee lended me a huge helping hand by showing me where to look for the information i was interested in. But what i found is why i stopped playing with the scangauge. It can read anything on the CANbus, but without the ability to work in logarithms it cannot display much of the informaion we were interested in finding. A couple of the things, iirc, that i(we) were hoping to pull out of the SGII were EGT/cattemp and AFR/Lambda. That data is on the bus, you just cant display it in any truly understandable fashion, unless you think in logarithms/exponentials
Old Nov 27, 2008 | 05:05 PM
How would the cat temp/egt not be linear? Wouldnt it be the same math as water temp or air temp just with a different sensor input?
Old Nov 27, 2008 | 05:20 PM
Asshole for hire
ah you may be correct, i havent gone back to look at what i found in the other thread, and i am working off memory. egt/cet temp may indeed be linear, it would actually make sense. I do know for sure though that O2 data is not.
Old Nov 27, 2008 | 05:27 PM
mysql's Avatar
Doppelgänger
I've already mailed them my scangauge once for a firmware update. Doing some simple math calculations seems within reason as a possibility for future upgrade
Old Nov 27, 2008 | 05:32 PM
Asshole for hire
that'd be nice but a day late for me. I'll have boost/vac, afr, oil press, water temp nexus gauges next time i drive the car so...
Old Nov 27, 2008 | 07:06 PM
oil pressure would be nice too i never thought of that. Better than the factory On/Off pressure gauge lol. I use to have an actual afr gauge on my acura and it displayed about the same info as the xgauge does. It jumps around depending on engine load and throttle position.
I have been searching other forums for info on codes but to no avail. I just spent 30 min on a mustang forum ::I feel so dirty now:: If you need me I will be in the shower with Clorox and an SOS pad.
I thought of another interesting xgauge I would like though. Radiator fan speed.
Old Nov 27, 2008 | 07:51 PM
Asshole for hire
i dont recall for sure, but i'm thinking that oil pressure is not floating around in our CAN bus. An AFR gauge in your previous car displayed similar 0-100 type data that you scangauge reports for O2 sensor in the RX-8?? A true wideband AFR gauge will display either air fuel ratio(roughly 10.0-20ish) or in lambda which will look more like 0.85-1.2 or roughly.
Old Nov 27, 2008 | 10:24 PM
This website had A Lot of info about xgauge stuff. Ive been cruising through some of the stuff to see if I can find anything interesting.
http://www.cleanmpg.com/forums
Also cam across this. Maybe it will help out in our search.
http://en.wikipedia.org/wiki/OBD-II_PIDs#Response
Old Nov 27, 2008 | 10:25 PM
mysql's Avatar
Doppelgänger
cat temp sensor is another one that I would like to see.
I had that with the canscan, but don't have it from scangauge or accessport.
Old Nov 27, 2008 | 10:41 PM
Asshole for hire
you're on the right track. after looking at it again, the wiki article tells you pretty much everything you need to figure out how to query for cat temp. good job!
from the forum you linked:
an interesting one
GAUGE: Manifold Air Flow
UNITS: g/s (0 TO 655.36)
CONF?:
->TXD: 68 6A F1 01 10
->RXF: 04 41 45 10 00 00
->RXD: 28 10
->MTH: 00 01 00 01 00 00
->NAM: MAF
NOTES:
Old Nov 27, 2008 | 11:00 PM
Just tried the MAF xgauge and it works great. Idle is around 78 g/sec. I think that is grams/sec from what I have read. That's a weird unit of measurement for air flow.
Old Nov 28, 2008 | 03:14 PM
r0tor's Avatar
idle should be around 6 g/sec
Old Nov 28, 2008 | 03:36 PM
Asshole for hire
g/s is a standard unit for mass airflow. but 78 is not even close to accurate at idle. possible that your actually flowing 7.8g/s at idle and the math function is just wrong?? i've seen cars idle damn near perfect to total crap and have seen 5g/s to about 8g/s.
Old Nov 28, 2008 | 05:00 PM
Yeah I got to drive my car off base (military) and the number was jumping all over the place once I got past 30mph. I will look into it there was more than one math function for it.
Old Jul 27, 2009 | 04:48 PM
mysql101's Avatar
got this list off a toyota forum
Air to Fuel Ratio (Lambda)
TXD: 07E02144
RXF: 04614544
RXD: 2808
MTH: 006400800000
NAM: AFL
Air to Fuel Ratio (True Air to Fuel ratio)
TXD: 07E02144
RXF: 04614544
RXD: 2808
MTH: 05BE00800000
NAM: A/F
Atmospheric Pressure (PSI)
TXD: 07E02133
RXF: 04610533
RXD: 2808
MTH: 000A00450000
NAM: PSI
another toyota site:
C3 33 F1 22 11 9E
04 62 85 11 06 9E
30 08
00 01 00 01 00 00
AFR
None
Air fuel ratio, > 14.7 is lean, < 14.7 is rich
I don't know yet if either will work for us.
Off some uk site for a vx22:
I tried the AFR yesterday when I took the car for a spin. From what I see on the display I am guessing this a calculated AFR that the ECU made up. If you look at the programming codes, you see that there are no maths aplied to the number on the display. When starting the car it displays:
147
Which sounds like a VERY familiar number if you assume this decimal and divide it by 10 : )
one of the cleanest xgauge installs i've seen:
http://www.verboom.net/projects/spee...016/index.html
Old Jul 28, 2009 | 10:50 PM
rx8dorifto's Avatar
none of them work.
