HKS SLD 3 z3 english diagram (speed limit removal)
Old Nov 18, 2008 | 09:45 AM
uk190's Avatar
for those of you with the Japanese spec, JDM, rx8 and are limited to 180kph.
the HKS SLD typeIII z3 works fine. it only takes 30 minutes to install, but when it activates at 180kph, it switches of the cars DSC system.
and i have attached the wiring diagram with english translation
File Type: pdf
Old Nov 18, 2008 | 09:52 AM
MazdaManiac's Avatar
I would be really interested to see how this device actually works.
That wiring diagram shows it to be spliced into the CAN bus, intercepting it before the PCM (and not into the speed sensor wires as the PDF indicates).
Old Nov 18, 2008 | 10:52 AM
MM, you should see the way HKS tap into GT-R's computer with their VAC.
Old Nov 18, 2008 | 10:54 AM
uk190's Avatar
i am no expert on which part of the ecu bus etc, but the diagram was supplied by HKS europe. and it works.
were you looking at the the ecu or the back of the ecu plug? from the wireside.
Old Nov 18, 2008 | 11:32 AM
Doesn't matter.
Those are pins 4V and 4S, which are CAN_H and CAN_L.
File Type: bmp
File Type: bmp
Old Nov 18, 2008 | 11:40 AM
HUSSAIN's Avatar
I have a japnese rx8 which locks up at 185kmph. I am thinking of buying one of these.
Is turning off of dsc the only side effect?
Does it hamper the car in any other way?
Is it safe?
What is JDM?
Have you installed it?
Any comments?
Where can I get it?
Old Nov 18, 2008 | 12:06 PM
a_ahlan's Avatar
Anji
Is it safe?
What is JDM?
Any comments?
Where can I get it?
You are better off spending a little more money and buying Hymee Scanalyzer Pro Tuner or Cobb AP (not sure if they support JDM yet). You'll be able to remove speed limiter and control a lot of other things by programming the ECU.
Old Nov 18, 2008 | 01:22 PM
uk190's Avatar
Is turning off of dsc the only side effect? according to HKS, yes.
Does it hamper the car in any other way?not according to hks
Is it safe?yes. hks again
What is JDM?jap spec cars
Have you installed it?yes
Any comments?it works
Where can I get it?online stockists. bought mine from an ebay seller
i considered the Cobb as it has a few other useful features, but apparently it doesnt work with jap spec cars. and i only want to remove the speed limit. ( at the moment)
Old Nov 18, 2008 | 07:33 PM
HUSSAIN's Avatar
What is the differrence between sld type 1, type 2 and type 3?
Does type 1 and 2 work with rx8?
Can somebody give me a direct link to sld which shall work with my manual 6 speed rx?
What is the expected price?
Old Nov 18, 2008 | 07:34 PM
HUSSAIN's Avatar
Is there any chance of cobb being released for rx?
Old Nov 18, 2008 | 08:22 PM
edited
reason : cuz this **** is completely overpriced. useless, causes CEL
Old Nov 19, 2008 | 12:02 AM
HUSSAIN's Avatar
Sorry i meant cobb for rx8 japnese version. So does anyone know when is it coming out.
Old Nov 19, 2008 | 02:59 AM
a_ahlan's Avatar
Anji
Contact Hymee for Scanalyzer Pro Tuner. Works on Japanese domestic model RX-8s like a charm.
Old Nov 26, 2008 | 09:52 AM
uk190's Avatar
MM..
i have no idea why this works the way it does, but it does
there no noticible effect as you hit 180kph, there are no CELs and the dsc doesnt seem to deactivate as HKS said it would. well, the light doesnt come on anyway.
shame really, as i think i might be removing it and opting for the AP when you are able to supply them.
Old Oct 19, 2009 | 02:23 AM
bencwloon's Avatar
how much for the SLD z3 ?
Old Oct 19, 2009 | 03:39 AM
chrisis's Avatar
sld Z3 is about 270 euro
check this out: http://cgi.ebay.co.uk/HKS-Speed-Limi...item43957e9d77
if you can pay 500 euro is better to purchase an access port from mazdamaniac and he can remove the speed limiter + you tune your rx8 for better performance and reliability.
pm me if you need more info.
Old Feb 13, 2010 | 02:05 PM
rodjonathan's Avatar
silent assasin
does anyone know if it actually works?
Old Feb 14, 2010 | 01:06 PM
kersh4w's Avatar
Hit & Run Magnet
the accessport works on european rx8s.
there have been quite a few turbocharged rx8s running the accessport.
Old Mar 10, 2015 | 03:19 AM
Hunterkelley24's Avatar
Sorry if it's dumb ....
This might be a dumb question but would this work on an rx8 in the United states ?
Old Mar 10, 2015 | 11:37 AM
There is no point, and it causes CEL, JDM or USDM
there is no speed limit on MT Rx8 sold in the states btw.
jay_tibo
22
Sep 13, 2016 08:10 PM
BlackEight
Far East/Asia
Jan 20, 2007 09:49 AM
RichTxz_id
Aug 11, 2006 08:36 PM
R888
Canada Forum
Sep 24, 2005 01:06 AM
