Is flooding more of an issue with ...
Old Dec 6, 2003 | 02:35 PM
melikeRX8's Avatar
Question Is flooding more of an issue with ...
AT or MT or both alike????
This flooding issue is starting to stray me from buying a RX-8.
Old Dec 6, 2003 | 05:41 PM
Racer X-8's Avatar
Coming thru in waves...
Flood the transmission?
Look, this car has a rotary engine. Consider it as a nuclear propulsion device if you wish, it's almost that different from a piston popper. Now, along with its inherent benefits, it brings to you also, its inherent idiosnycracies (if I spelled that correctly, I win $1000, OK?). One of the (____, yeah, what I said) is that you better not turn it off before it gets up to temperature. That may take 5 minutes, maybe a tad longer in the great white north at this time of year. If that's too much to handle, well, uh... you better "stray". You like RX-8? Fine, but let her warm up before you shut her down. As opposed to female-types, she won'tflood on you if you warm her up. That's just the way it is. And it's real easy to remember. And even if you don't follow this real simple rotary rule, most of the time you'll be alright anyway. It doesn't flood every time. I've had mine for 4 months and never was stupid enough to forget this simple rule. I pushed it a couple times instead of cranking it up. It pushes easily, especially downhill :D
Old Dec 6, 2003 | 06:25 PM
Rick's Avatar
I have not flooded my A/T and I start and stop it cold. However, if it should flood, I am prepared to fix it.
Old Dec 6, 2003 | 08:24 PM
s1mike22's Avatar
the fact that an rx 8 is A/T or M/T shouldn't change anything. if you stop the engine cold, you run the risk of flooding it as well.
Old Dec 6, 2003 | 08:35 PM
MEGAREDS's Avatar
Goh Mifune
It's just not a big deal... really.
RevMeHarder
Jun 1, 2026 02:30 PM
gwailo
May 14, 2024 06:57 AM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
DVerdeyen
Sep 13, 2015 11:19 AM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
