Replacing Tyres..Help me Choose...Only three choices available in my country:p
Old Nov 13, 2008 | 02:46 AM
HUSSAIN's Avatar
Want to replacy my tyres mounted on stock rx8 rims. The following three tyres are available in my country for rx8. Sadly all three of them are 225/40/r18. So what do you suggest:
1.. Dunlop SP Sport 9000 225/40 R18 for passenger cars
2. Yokohama AVS ES100 225/40 R18 for passenger cars
3. Bridgestone Potenza G3 225/40 R18 for passenger cars
I did some search on this forum before posting and read people suggesting that 225/40's should not be mounted on stock wheel. However the yokohoma tyres have recommended rim width of 8" which is equivalent to rx8 stock rim. So what should i Do; I also have some options available in 215/40 category.
Thanks Again
Old Nov 13, 2008 | 05:05 AM
HUSSAIN's Avatar
help
..sorry in advance for bumping
Old Nov 13, 2008 | 12:43 PM
987HYS's Avatar
Dragon Certified
Potenza 225/45 or 235/40
Old Nov 13, 2008 | 01:16 PM
dothackRAVE's Avatar
<3 Rotary
Where do you live? I find it hard to believe that no manufacturer on this planet except the three listed above have the ***** to step into your country and make a profit.
Old Nov 13, 2008 | 01:49 PM
dozer's Avatar
on his 3rd rx8
potenzas...
Old Nov 13, 2008 | 07:21 PM
RX26b's Avatar
Doesn't appear that the manufacturers are the problem; afterall, those three are pretty reputable and make some nice hi-po tires. Where the hell is the rest of their line....and where are the proper sizes?
Two words Hussain: mail order
Old Nov 13, 2008 | 07:22 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
He's in Pakistan
I'd go for the Potenza's as well.
Old Nov 13, 2008 | 07:47 PM
GaMEChld's Avatar
Registered Noob
What's wrong with 225/40?
Old Nov 14, 2008 | 01:46 AM
HUSSAIN's Avatar
As i said there are no other options available. The only option available are the three tires mentioned is dunlop sp 9000, potenza g3 and yokohoma es100. Furthermore the only size these three tyres are available are 225/40.
I don't know much about tyres but there are reviews available about es100 and dunlop sp 9000 on tirerack.com. However no reviews are available for potenza g3.
So question here is pretty simple.
1. So should i go with a 225/40 tyre. What difference would an a 225/40 tyre make in an rx. The recommended rim width for all of the above tyre is 8" inch which is the same as rx.
2. If yes to above, which tyre should i go with.
Old Nov 14, 2008 | 02:48 AM
GaMEChld's Avatar
Registered Noob
I meant what's so bad about 225/40? Since you said "sadly" they are 225/40. Just slightly lower profile than stock, same width.
I hear the Yokohama brand is good, no experience with it. I'm no tire guru, but try finding those tires on www.tirerack.com and see how they all compare in ratings and reviews.
Personally, my current favorite that I vouch for is the Sumitomo HTR Z III. I run that in 245/40/18.
Old Nov 14, 2008 | 03:42 AM
HUSSAIN's Avatar
That's exactly something i am asking. Is there anything bad about 225/40 or is it allright to put them on rx. And if it is okay which tyre should i go for.
Old Nov 14, 2008 | 09:25 AM
alnielsen's Avatar
They should be fine. Your speedometer reading will read a little higher than is should and you will put a few more miles/km on the car than with the OEM size. The 245/40/18 size should be close to the same diameter as the OEM size. There would be no change to the Speed/Odometer.
It seems that the Potenza G3's are available in Australia in the 235/40/18 size. If that option is available to you that would be closer to the OEM size.
Old Nov 14, 2008 | 09:38 AM
Huey52's Avatar
Registered Zoom Zoomer
A slightly rougher ride due to the lower profile (not as much volume to absorb shock; doubtful noticeable), and the slight speedometer/odometer offset, but nothing 'bad' going with 225x40 on the stock 18" rims. Of the three I prefer, in descending order:
Dunlop
Yokohoma
Bridgestone
Old Nov 14, 2008 | 04:43 PM
GaMEChld's Avatar
Registered Noob
The OEM's are 225/45 if I recall, so my 245/40's would be smaller in diameter (the 45/40 being the tread height), thus my speedo would be slightly off. But not a big deal.
Yeah the 225/40's will work just fine. Just know that your speedo will be slightly off.
Come to think of it, how much of a difference does 45->40 make to the speedo? I completely forgot about that while driving around. So I'm going slower than I thought I was?
Old Nov 14, 2008 | 09:59 PM
HUSSAIN's Avatar
So which tyre brand should i go with and any reason for that?
Old Nov 15, 2008 | 09:14 AM
alnielsen's Avatar
The 40/45 is the ratio of sidewall height to tread with. Because you have increased the treadwith from 225 to 245, the height of the sidewall increased. Therefor, the 225/45 is equivalent in diameter as a 245/40 tire. Of course, these sizes (actual measured width, sidewall height & diameter) varies by manufacturer
Old Nov 15, 2008 | 09:17 AM
Mazurfer's Avatar
Wooops! Nevermind, I mis-read the 245!
Old Nov 15, 2008 | 02:48 PM
GaMEChld's Avatar
Registered Noob
Ah..... so its a ratio. Thanks a bunch for that fun fact.
Old Nov 16, 2008 | 10:10 AM
HUSSAIN's Avatar
I have found another tire in the market know as dunlop direzza 101. So now my choice is down to dunlop direzza and dunlop sport 9000.
I cannot understand the difference between the two tyres as they are very similarly priced. So which one should i get of these two.
http://www.dunloptires.com/dunlop/di...ea=Performance
http://www.dunloptires.com/catalog/direzzaDZ101.html
Old Nov 16, 2008 | 10:51 AM
Huey52's Avatar
The Direzza is a Summer Max and the Sport 9000 is a Summer Ultra.
Max generally has a bit more grip than Ultra, but as it's a softer compound it doesn't wear quite as long.
Compare on Tirerack.com
Old Nov 16, 2008 | 11:55 AM
HUSSAIN's Avatar
Actually Sp Sport is Summer Max whereas Direzza is Ultra Performance. I think you mean to say that Direzza Wears Out quicker?
Old Nov 16, 2008 | 02:09 PM
hakuna matata!
I've been running DZ101's this entire summer.. they are fantastic in hot and wet conditions.
Old Nov 16, 2008 | 03:34 PM
GaMEChld's Avatar
Registered Noob
I've used DZ101's for about 20K miles. Using Sumitomo HTR Z III's now, far far far superior. Do not know how long they will last though.
Old Nov 17, 2008 | 09:43 AM
Huey52's Avatar
Darn, I meant to type that the Direzza is Extreme performance and SP Sport is Max, but same principle, so yes the Direzza will most likely wear out quicker. My OEM Dunlop 8090's are Ultra.
The order of grip goodness in descending order (but thereby also quicker wear) is:
Extreme
Max
Ultra
Zank300
Aug 26, 2015 07:40 PM
Feffman
MW RX-8 Forum
Aug 23, 2015 01:27 AM
Feffman
RX-8 Racing
Aug 15, 2015 06:21 AM
Red Ryno
Jul 24, 2015 09:06 PM
Jvswan
28
Jul 23, 2015 09:02 AM
