RX-8 Media News Report the latest RX-8 related news stories here.
'09 RX-8 R3 Short Take Road Test - Car and Driver
Old Nov 6, 2008 | 02:04 PM
s204speed's Avatar
Sounds like they still appreciate it for what it is; but with so many high-horsepower cars I'm sure they wouldn't mind a twin-turbo in the next RX!
2009 Mazda RX-8 R3 - Short Take Road Test
New sports coupes arrive like summer lightning and depart like uneaten guacamole: ignored, slowly fading to brown, awaiting the inevitable flush. The six-year-old Mazda RX-8 languishes through 2008 with sales the Hubble telescope wouldn’t register: just 2591 units through the end of August.
Mazda isn’t giving up, however. The Hiroshima headquarters considers rotary engines integral to its identity, so the RX-8 stays, a place keeper for a future all-new rotary engine currently code-named “16X” and due perhaps by 2012.
Meanwhile, the RX-8 gets a little stir to keep it green. Most obvious is the new front bumper that flares the grille and brake-duct openings for a more dangerous, grinning-cobra menace. Four glassy robot eyes now fill the taillight teardrops, the exhaust tips are bigger, and fresh wheel designs adorn the various trim levels.
http://www.caranddriver.com/reviews/...take_road_test
Old Nov 6, 2008 | 03:15 PM
chancejat's Avatar
Drive it like u stole it!
numbers are slower....17.7 to 100....my car takes like just under 16...wtf
Old Nov 6, 2008 | 03:34 PM
DarkLord7854's Avatar
Software Engineer
I wish they had a red R3 available when I went to get mine.. oh well
Old Nov 6, 2008 | 04:48 PM
bulletproof21's Avatar
and their 0-60 was 6.7....yuck
Old Nov 6, 2008 | 05:06 PM
LionZoo's Avatar
road warrior
I notice they list the weight as 3,110 pounds. Did they actually weigh a R3 and it proved to be that much?
Old Nov 6, 2008 | 08:41 PM
TrochoidMagic's Avatar
is adjusting valve lash
^^ i read 3060... so which is it?
either way, the new one is more flubby. but that extra 20lbs and lower #s hardly does the R3 any justice... the looks on that car is awesome. its growing on me.
the higher mouth entrance on the front end looks easier to modify assuming the vfad is in the same place...
Old Nov 6, 2008 | 10:15 PM
mikefrombarrie's Avatar
Instead of reducing the weight of the RX-8 they ADDED more to it!
But its not Mazdas' fault, its the customers who want their cars to be "fully loaded"
Old Nov 7, 2008 | 03:05 AM
LionZoo's Avatar
road warrior
Sorry, the 3,110 is from Road & Track. The 3,060 is from Car and Driver. For ostensibly the same car, that's a big difference.
Old Nov 7, 2008 | 09:03 AM
VS8's Avatar
VS8
4 Cylinder Rotary
i just got to sit in one at san antonio dealership...i love those recaros and those wheels
Old Nov 7, 2008 | 09:24 AM
JRichter's Avatar
Void Where Prohibited
...and notice Road & Track got quicker acceleration numbers and higher top speed in this month's Road Test Update.
Old Nov 7, 2008 | 09:34 AM
9291150's Avatar
It's likely they're testing a very green engine. Car & Driver had times nearly as bad with their long term 8 when new, and at 30000 miles they did the usual 5.9/14.5 times.
Surprised the new gear ratios didn't help, particularly with the trap speeds.
Old Nov 7, 2008 | 09:39 AM
VS8's Avatar
VS8
4 Cylinder Rotary
so who is lying road and track or car and driver
Old Nov 7, 2008 | 02:29 PM
Rotary Mike's Avatar
Registered 407 Abuser
I think 9291150 explained it best. The rotary engine needs some mileage on it to make it perform better.
I'm surprised no one has mentioned the wheels yet. 19" rims can't do much to improve acceleration times.
Old Nov 7, 2008 | 02:58 PM
JRichter's Avatar
According to a couple of tests I've read on the '09, an additional shift is required before 60 mph is hit with the different gear ratios so this explains a slower 0-60. Anyone with an '09 verify this?
Old Nov 7, 2008 | 03:36 PM
Software Engineer
I can hit 60mph in 2nd gear easy, I think the highest I can go in 2nd is just about 70mph, but I know I can do 60mph at least
Old Nov 7, 2008 | 04:40 PM
chancejat's Avatar
first gens hit 67 in 2nd gear...
Old Nov 7, 2008 | 04:44 PM
wantan8's Avatar
Can't see why it would drop off to below 60 then if the first gen hit 67 in second.
chancejat's Avatar
bc of diff gearing....4.77 vs 4.44...but i was thinking it would hit 61 or 62 at least......but thats only on the r3...not the touring, gt,or sport.....so someone with an r3 needs to chime in...or make a vid or somethin
Old Nov 7, 2008 | 05:23 PM
JRichter's Avatar
Yeah I was gonna say like 67-68 for mine.
The low-torque RX-8 was always tricky to get rolling without a stall. A shorter rear-end ratio in all 2009s—4.78:1 versus 4.44—means less revving and clutch slip in everyday driving. However, the second-to-third shift is now perilously close to 60 mph, which likely slowed the acceleration runs (6.7 seconds to 60 mph versus 6.5).
C and D just says this which I guess depends on how long you hold the rev - I'm sure they take it to redline but probably not to fuel cut as they are doing a full acceleration run - not just to 60 and quit.
Old Nov 7, 2008 | 06:55 PM
I started another thread earlier that has the braking much longer.
It has numbers of a sedan.
Old Nov 7, 2008 | 07:12 PM
77mjd's Avatar
I thought someone had mentioned in another post that the new 19" wheels are actually lighter than the stock 18's on the '04-08s.
Old Nov 7, 2008 | 07:32 PM
chiketkd's Avatar
Row faster, I hear banjos
FWIW, years ago when Best Motoring released the Factory Fighters dvd, they tested the Mazdaspeed RX-8 against the standard model. The MS came with the full coilover suspension, body kit and 4.77 rear end.
In their 0-60mph and 1/4 mile testing they found the standard model (w/ 4.44 gears) to be faster -- I think they said the 4.77 geared RX-8 wasn't in the strongest part of its powerband for very long, before an upshift was needed.
Old Nov 7, 2008 | 07:40 PM
lone_wolf025's Avatar
Future Rotary User
So it sounds like the new gen has a better engine setup in terms of reliability, but with the 4.78 rear end doesn't help things any. Someone refresh my memory, what was the ratio with the FEED gear?
Old Nov 7, 2008 | 09:41 PM
Software Engineer
Well I just tried it out again, 8k gets you to 57mph, 9k gets you to 62mph,10k and fuel cutoff gets you to 66mph
Old Nov 8, 2008 | 11:26 AM
lepichichi's Avatar
I LuV mY Rotary....
R3's are so nice
