Another (different) DRL problem
Old Oct 28, 2008 | 10:45 AM
Redshift's Avatar
Spinning Dorito Junkie
Figured I would post this in here since it wouldn't apply to the US cars.
When I let off the parking brake, the DRLs do not come on, and the little green dash light stays off. If I slowly move the parking brake up an down and get JUST the right position, they will sometimes come on. (But not always.)
I've searched, but only found info on the common DRL module failures, which I don't think is my problem. When I turn the headlights on the DRLs come on (as does the little green dash light) my high beams, fogs etc. all work.
So, I'm pretty sure it's the switch on the parking brake lever that's acting up. I've searched, but not found anybody else having this problem. Has anybody heard of this? Anybody have any other theories? Figured I would ask for some ideas before I tear apart the center console, as I'd like to be prepared to fix it while I'm in there.
Old Oct 28, 2008 | 10:51 AM
StealthTL's Avatar
It's no biggie to 'tear the console apart', I did it twice yesterday.
Just lift gently at the cup holder end, then ease the whole thing straight up - don't twist or bend or you'll snap the little connector plugs off.
If you have heated seats, unclip the two switches and lift the whole thing up around the shifter. Just leave it there, no need to take it right off, the switch is obvious, and easy to work on.
Probably just needs a shot of WD-40.
S
Old Oct 28, 2008 | 11:10 AM
Footman's Avatar
Dodging those Corollas
Check the parking brake relay? When you let off on the parking brake, you can hear a distinct "click". that is the relay contacts being activated. The relay contacts may be sticking.
Old Oct 28, 2008 | 11:33 AM
AmKorp's Avatar
I think the relay is activated by the switch that Stealth was talking about. That is more than likely the problem. If it does need to be replaced I wouldn't think it to be too expensive or a hassle to change out.
Old Oct 28, 2008 | 11:53 AM
Redshift's Avatar
Thanks for the tips.
If it was the relay, wouldn't the DRLs stay off when I turned the headlights on? They do come on, so I'm thinking switch. I don't hear any clicking either.
As for the "tearing it apart" I know it's not that hard, but I guess I should have mentioned that clips hate me. No matter how careful I am, anything I work on that has clips, one always breaks. So, don't want to dis-assemble more than required.
Hell, I think half of my shirts have even had a button come off them....
Old Oct 29, 2008 | 06:01 AM
AmKorp's Avatar
When you turn the headlights on you are, in fact, turning the headlights on. The DRLs do not function when the headlights are on. You'll either have your HIDs or full headlights (depending on the model of your car). I really wouldn't bother taking this to someone to look at as you'll spend uneccessary money.
The switch is right under the panel that surrounds your shifter. Easiest way, I find, to remove that panel is to grab the inside edge of the shifter boot with both hands (9 o'clock and 3 o'clock positions) and just pull straight up (you can remove the shift **** as well by just unscrewing it). Once that panel is off you'll see the switch right under the hand brake lever. Just try activating it with your finger, maybe spray some WD-40 on it. If it still doesn't work, replace it.
That should fix the issue.
Old Oct 29, 2008 | 07:16 AM
Redshift's Avatar
My DRLs have always come on (stayed on?) with my headlights. This morning (I was playing in the driveway while waiting for the girlfriend) I had 0 lights on the front when I started the car, and 6 sources of light when I turned on the headlights (The HID standard beams, the fogs and the small DRL bulbs on the very inner corner of the headlight unit.) From the pictures I've seen of other people doing the bulb conversions, this is normal, isn't it?
Thanks for the tips on the switch location. Haven't had the console apart since I installed the AFE shifter a few years ago, so was hazy on how to get in there. Trust me, no worries about taking it to somebody and wasting money. The only time my 8 has been inside a dealership was when I was getting the 3-years free maintenance. I've done all of my own maintenance outside of that, and installed my own parts.
Old Oct 30, 2008 | 03:53 AM
AmKorp's Avatar
I see what you mean as DRLs. Those small lights on the very inner corners of the headlight housing are your parking lights, not Daytime Running Lights (DRL). The DRLs are the highbeam bulbs running at half power.
So when you have your light switch in the off position, and the handbrake is down, you should have your highbeam bulbs, at half brightness, only. When you switch the light switch to the first position, you should have the same highbeams at half brightness as well as the smaller parking lights. Then at full on, the HIDs and the parking lights should be on, but the DRLs should be off.
Is this the case or is it something different?
Old Oct 30, 2008 | 05:54 AM
Redshift's Avatar
Hmm... this seems really odd. After 5 years of owning this car, you'd think I would have noticed before. You're right. For the last 5 years I would have sworn it was the park-lights that are coming on as DRLs, but after the better half telling me I was wrong, and then spending a few minutes in the driveway this morning messing with the lights to prove I wasn't, it looks like I was. So, forget all the stuff I said about the DRLs coming on when I turn on the lights. I guess I am as oblivious as she says.
So, we did do a little test and while slowly moving the parking brake up and down, the DRLs will briefly flicker, so it looks like it is the switch. I also noticed that one of my high-beams is burned out (I don't use them much) so it was a useful experiment.
*Edit due to the fact I'm an un-observant idiot.
Old Mar 9, 2010 | 01:50 PM
pauleta's Avatar
Did it end up being the switch? I would think if it was the switch, then the parking brake light wouldn't come on on the dash either.
I had the same problem a while back while under warranty, if I jiggled the parking brake the DRLs would flicker but didn't work when the brake was down. Eventually died completely. Mazda replaced the DRL module not the switch. It happened again just over a year after, while out of warranty, they wanted to charge me. I figured I could do it myself (haven't gotten around to it yet)
Old Mar 9, 2010 | 07:47 PM
MyRxBad's Avatar
Fb's rock!
If one of the high beams are out, then replace it. If you are lucky, it's just the light, but I have a feeling that your DRL module is toast...
Old Mar 12, 2010 | 07:39 PM
WarpFactor's Avatar
I have the exact same symptom as the original poster. I've wondered if the problem was the parking brake switch too, but I have as yet to get a response from anyone saying they replaced it and fixed the problem. Seems like a lot of people come to this board looking for help, but when they fix their problem, they don't bother telling us what they did.
I did go as far as taking the DRL module out and tried to find new relays to replace the ones on the module. But no one sells them in lots of less than 30! I only want 2!
Old Mar 13, 2010 | 12:04 AM
climacus's Avatar
When your DRL module goes wonky, the handbrake switch start acting funny too. So no, chances are there is nothing wrong with your handbrake switch.
Old Mar 15, 2010 | 12:42 AM
Delmeister's Avatar
Actually the DRLs run at half voltage which is about a quarter power (Assuming the resistance doesn't change too much...P=V*V/R)
Old Mar 15, 2010 | 02:34 PM
Redshift's Avatar
Wow. I forgot I even started this thread all that time ago.
I swapped out the DRL module, cleaned the parking brake switch with contact cleaner etc. Nothing fixed it. In tried problem-determination method, I put the original DRL module back in and kept trying to figure out the problem.
Then I thought, "well, while I'm in taking everything apart, I might as well replace that burned out bulb."
New bulb, old DRL module, everything worked again. So, it was just a bad bulb the whole time. I had heard the burned out bulb will kill the DRLs, but didn't think it would let them flicker on and off while messing with the parking brake. Really odd.
At least I have a spare DRL module on the shelf now for when it does indeed fail.
Old Mar 24, 2010 | 01:33 AM
huckfarper's Avatar
How much did that drl module cost you? Mazda just replaced one for me and wouldn't tell me how much it would've cost had I done it myself...
Old Mar 24, 2010 | 06:16 AM
Redshift's Avatar
Aprox $100 as I recall.
Old Mar 25, 2010 | 04:16 PM
Mazda_RX804's Avatar
Hate Scrape 8
i have the same issue. Ebrake down, DRL's are off... But when I flick on the Xenon the are on.
Old Jun 13, 2011 | 01:32 PM
2hit6's Avatar
My car has a similar issue...
We I release my parking brake...sometimes the DRL would come on, sometimes only the left DRL would come on and at times both would not come on. Can't seem to figure out what it could be... any ideas? Have anyone successfully fixed it? Is it the contact switch?
Old Jun 13, 2011 | 03:40 PM
DarkBrew's Avatar
Extraordinary Engineering
There's a place that sells them in small lots. (mouser.com)
Also I have 8 relays.
Handbrake switch is one of the inputs to the relay controls for DRL
Old Jun 14, 2011 | 12:10 AM
tonik's Avatar
same symptoms w/ mine before...replaced the DRL module and problem solved..
Old Jun 20, 2011 | 09:52 AM
pauleta's Avatar
Do your high beams work? I had similar problem with DRL not working but with high beams on one light worked, the other was burnt out. Replacing the dead bulb fixed the DRL.
Old Jun 20, 2011 | 12:10 PM
DarkBrew's Avatar
Next DRL failure see my DIY DRL repair!
Old Jun 20, 2011 | 10:22 PM
2hit6's Avatar
Thanks to DarkBrew for doing my DRL....Awesome character! Beers on me the next we do another install meet!
Old Jun 30, 2011 | 11:26 AM
tonik's Avatar
That would be next so I can have a spare module...
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
