DIY CAI question
Old Oct 25, 2008 | 12:10 PM
peckax's Avatar
DIY CAI question
I bought some eBay pipes, and I made my own CAI. it goes through the stock airbox because of the sensor. Though the pipes i bought were 2.5" Which is narrower than what the stock or even aftermarket intakes are. So i had to use a reducer. My question is would this cause any problems/performance loss as the pipe is lower in diameter?
Old Oct 29, 2008 | 08:42 PM
Silver_Mazda09's Avatar
Stop Looking @ my Rotary!
Making your pipes smaller, would cause air flow problem and easier to heat up quicker under the bonnet. good luck.
Old Oct 29, 2008 | 08:50 PM
Jon316G's Avatar
Grasshopper
AEM uses a 3.5-3.0 reducer coupler on their intake setup.
I wouldn't restrict airflow anymore than that.
Old Oct 29, 2008 | 09:23 PM
em1turbo's Avatar
bad idea dude.
Old Oct 29, 2008 | 10:42 PM
05rex8's Avatar
sold the 8... :(
won't that mess with the MAF too?
Old Oct 29, 2008 | 11:08 PM
shaunv74's Avatar
Power!!
What is the formula for Mass Flow rate? What does Diameter do to it? Once you figure it out you'll have your answer.
Old Apr 13, 2009 | 05:31 PM
peckax's Avatar
ok guys, now i ave another problem, i was DIY another CAI just right now with 3.5" pipe. also i made a short ram intake. made my own fire wall or heat shield, drilled hole for a sensor in the pipe and using epoxy atached sensor mount.when i put everything together i start the car and runing after couple seconds turns off. and when i try to step on gas it dies right a way.does anyone knows what is wrong this time? is the pipe too big?thanks
Old Apr 13, 2009 | 06:15 PM
Red Rex's Avatar
You could potentially throw off your MAF sensor readings, and loss of power would be the least of your problems.
Old Apr 13, 2009 | 08:46 PM
peckax's Avatar
AU
Throw off the sensor by what? By having a 3.5" pipe? is that too wide in diameter? Please explain.
Old Apr 13, 2009 | 09:15 PM
Jon316G's Avatar
Grasshopper
Any pipe size different than OEM will need to be tuned for the larger/smaller size.
This will throw-off the MAF sensor.
Easier to just keep it the same.
Forevermore
Sep 20, 2015 01:04 PM
yankeepicker
Sep 11, 2015 05:42 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
