Steering Knocking Noise - Problem FIXED
Old Oct 8, 2008 | 01:36 PM
Prototype_uk's Avatar
For details see my original post https://www.rx8club.com/series-i-tech-garage-22/clonking-knocking-going-over-bumps-156290/
Basically the knocking noise was finally found to be a faulty steering rack after changing it for another one in desperation.
My car has done 6125 miles and is 19 months old.
Thought I would post the solution as it was so hard to find I think they almost gave up because you wouldn't expect it to be the rack lol
Old Nov 8, 2021 | 01:51 PM
BlackCopperR8's Avatar
Originally Posted by Prototype_uk
For details see my original post https://www.rx8club.com/showthread.php?t=156290
Good Day, Im Having a similar issue, little elevations in the road and bumps, will cause this ungodly rattle noise. You can almost feel it in the steering as well. However when I'm up to speed on smooth highways with little ups and downs the car holds really well with no sound. I've had two suspension shops check it out, and they said that the suspension components are in good shape. They did say however that my caliper pins needed greasing which I assume is for a totally unrelated minor problem, it was just a suspension check up after all. Im beginning to suspect its my Steering Rack, but before I replace the whole thing, is there a way to change out the bad component instead ?
Old Mar 13, 2022 | 09:30 PM
johnnyg21's Avatar
Hello there, you ever figure out what the problem was? I'm having the same issue the noise is unpleasant when driving?
Old Mar 13, 2022 | 09:37 PM
Unfortunately not, no responses and im still having the issue
Old Mar 14, 2022 | 03:11 AM
johnnyg21's Avatar
when the weather gets warmer in my area. I will do a more thorough examine to find the problem and when I find it I'll be sure to share it with you.
Old Aug 15, 2022 | 09:08 AM
nicokurniawan's Avatar
same problem here. Have u already fix it?
Old Aug 15, 2022 | 04:50 PM
unfortunately no still have it to this day
Explode64
Australia/New Zealand Forum
96
Feb 29, 2016 02:16 AM
charlie c5
Oct 4, 2012 07:51 PM
RX TION
Oct 31, 2010 05:57 AM
