amp and sub install on the Bose?!?!?!?
Old Oct 2, 2008 | 09:15 AM
wb rx-8's Avatar
HKS Posterboy
has anyone installed an amp and a sub on the Bose system. Someone please help
Old Oct 2, 2008 | 09:36 AM
invasion08's Avatar
Yes i have. I put in one 10inch jl audio w3 and amp. There is an adpater that you need to hook this up to the bose system which hook ups behind the radio.
Old Oct 2, 2008 | 10:15 AM
Socket7's Avatar
ಠ_ಠ
Yes!
I hope this helped!
Old Oct 2, 2008 | 10:44 AM
wb rx-8's Avatar
HKS Posterboy
yeah it did help but what adapter do i need. and do you have any any step by step help on how to hook it up. im also in the process of building a false floor and a custom box
Old Oct 2, 2008 | 10:55 AM
Juansito's Avatar
Redlined
OMG i been looking for just this!
Is there a DIY? I would love a step by step and all the stuff i need.
Old Oct 2, 2008 | 11:26 AM
wb rx-8's Avatar
HKS Posterboy
LOL I know me too. Ive had the stuff since I bought the car in June LOL. But I need a step by step n wut adapter LOL
Old Oct 2, 2008 | 12:15 PM
Never fear, Jedi is here!
you will need an LOC and you want to tap the rear speakers for your sub connections.
here is my setup: https://www.rx8club.com/series-i-interior-audio-electronics-24/jedis-bose-stereo-upgrade-103771/
Old Oct 2, 2008 | 12:34 PM
mikesol's Avatar
gas kilometerage
If you're cheap, you can just cut into the signal before it goes into the Bose amp in your trunk like I did. Use little wire splices, and the color code in the other thread:
https://www.rx8club.com/showthread.php?p=252129
Works fine going right into my amp's RCA inputs. I used the pink wire as my power on trigger. No problems so far!
Old Oct 2, 2008 | 12:47 PM
wb rx-8's Avatar
HKS Posterboy
where do I buy the adapter
Old Oct 2, 2008 | 12:50 PM
you're KILLING me smalls, you're killin' me!!
Click on my link.
Old Oct 2, 2008 | 01:05 PM
wb rx-8's Avatar
HKS Posterboy
Oo LOL my bad I been in school all day. Now my brain is on standby LOL
Old Oct 2, 2008 | 02:35 PM
wb rx-8's Avatar
HKS Posterboy
isn't there another way to beef up the bass in the Bose without puttin an amp n sub?
Old Oct 2, 2008 | 02:37 PM
nope, not with those speakers.
you COULD just replace the rears with something like the Infinity's I used. they should have a little more low end power then the bose.
You could also get one of those 'bazooka tubes'
Old Oct 2, 2008 | 02:43 PM
wb rx-8's Avatar
HKS Posterboy
O ok cause my friends srt4 has a Bose I think they made a couple hundred with Bose and his Bose has more bass than mine =[ we were trying to figure out why cause he has the same speakers so we thought there was another way to beef it up.
Old Oct 2, 2008 | 03:09 PM
not all bose are created equal. My buddy has a nissan altima with bose and his sounded better.
(which is why I ripped mine out and threw it in the trash)
P.S. got your PM. It was made by a buddy of mine years ago.
Old Oct 2, 2008 | 03:39 PM
wb rx-8's Avatar
HKS Posterboy
LOL damn srt4 n altimas LOL. Thnx for all your help guys
Old Oct 3, 2008 | 11:56 AM
Socket7's Avatar
ಠ_ಠ
Rear deck, front tweeters, and front center channel can all be replaced with aftermarket speakers while keeping the bose amp. door woofers, not so much.
Old Oct 3, 2008 | 02:12 PM
New2u's Avatar
it's not so much that all speakers aren't created equal, which they can differ... but mainly the difference in the quality that you hear is the acoustics of the car, every car will sound different with the same speakers.
Old Oct 3, 2008 | 03:11 PM
wb rx-8's Avatar
HKS Posterboy
explain more
Old Oct 3, 2008 | 03:37 PM
Socket7's Avatar
ಠ_ಠ
explain more
More means that one thing is a greater amount then another.
You should really read the stickies in the interior/electronics section of the forum.
Old Oct 4, 2008 | 01:12 PM
The Korean's Avatar
Ninja
I have 2 10" JL Audio W0 along with a 600 watt Koiiler amp installed with the bose system. You can buy that harness pretty much at any local electronic store that sells car audio. BTW, when you hook into the system you might need to install a toggle switch to manually turn the amp/subs on and off. The Bose system tends to give the amp/subs power first before the speakers which causes a nice loud hummmmm...
Old Oct 23, 2008 | 11:43 PM
kanedrz's Avatar
kanedrz
The infinity speakers sounds better than the Bose speakers? Isn't the Bose suppose to be high quality?
Old Oct 23, 2008 | 11:47 PM
StealthTL's Avatar
......."suppose to be"..........
Very true.
S
Old Nov 5, 2008 | 06:22 AM
ducttape4054's Avatar
i have a kicker L7 10in with a 600watt alpine amp. what i used to get everything together(and sounding the best it can) is a processor. u can tune everything with it, it about the size of a small amp. it a lil expensive on install cuz it takes a few hours to dial it all in but well worth it.
Old Nov 6, 2008 | 06:27 PM
dozer's Avatar
on his 3rd rx8
Yes You Guys Saved My Life!!!!
