Dash Warning Light
Old Sep 26, 2008 | 03:10 PM
xO MazdaRx8 Ox's Avatar
D R ii F T
Question Dash Warning Light
i recently had a light pop up on my dash that looks like a tire low on air with and exclamation point in the middle. i was told that one of my tires is low on air so i filled each tire. the stupid light is still on and won't go away. any help out there???
Old Sep 26, 2008 | 03:14 PM
quazmosis's Avatar
Chode
I'm guessing it will go away once you turn your car off and back on. (if you filled you tires up to the correct psi.)
Old Sep 26, 2008 | 03:24 PM
D R ii F T
thats what i thought too but even after reseting the computer the stupid light remains on. could i have a bad sensor or something??
Old Sep 26, 2008 | 03:29 PM
greg985's Avatar
The 337
what psi did you fill your tires to?
Old Sep 26, 2008 | 03:35 PM
D R ii F T
i have avons on there now and they say max 35psi so i went up to a hair under 30psi
Old Sep 26, 2008 | 03:48 PM
greg985's Avatar
The 337
someone correct me if i am wrong, but doesnt the warning light come one when any tire goes under 30 psi. So you may have one tire that is still "low". Try 32 psi
Old Sep 26, 2008 | 03:54 PM
D R ii F T
i will do that as soon as i get home i will let you know if it works, thanks in advance
Old Sep 26, 2008 | 04:10 PM
JTtheDude's Avatar
I think I read somewhere that it needs to be over 32 for the sensor to stay off, if you filled to less than 30 you need more. 32-35 keeps it off unless it gets really cold outside.
Old Sep 26, 2008 | 04:13 PM
invasion08's Avatar
The TPMS will turn on if the psi is too low or too high. Let the car sit overnight and check the psi in the morning. There should be 32 psi in each tire.
Old Sep 26, 2008 | 10:31 PM
the low and hi are 26 and 52 psi.
Old Sep 26, 2008 | 11:19 PM
greg985's Avatar
The 337
damn 52
Old Sep 26, 2008 | 11:55 PM
Originally Posted by greg985
damn 52
yep.
that is in a very obscure tsb that i hope i dont have to find again..
Old Sep 27, 2008 | 10:47 AM
ken-x8's Avatar
Do they really say max 35 psi? The max value on the sidewall is usually higher - like 40 to 50 psi - and is not the recommended inflation pressure. It's the max that a tire installer should use to seat the bead. The proper inflation pressure is what the owner's manual or sticker in the door jamb says - which is 32 psi for an RX-8.
If you have a bad TPMS sensor, figuring out which one is bad can be tough. You'd need a code scanner that reports the psi value from each tire. Then you add/remove air from each tire to figure out which one is which. If you're still under the bumper-to-bumper warranty, take it to the dealer and let them figure it out.
Ken
Old Sep 27, 2008 | 06:45 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Swoope is right about those numbers.
AND............sometimes you have to drive the car for about 5 miles before the light will go off. Sometimes just letting it sit apparently won't do it.....although I have never tried that..............I just go for a drive.
Old Sep 27, 2008 | 07:33 PM
kersh4w's Avatar
Hit & Run Magnet
my tpms light went on and arlington mazda let me down. they said they didnt see any codes (even though its been on a week) and it wasnt on for me.
and it wasnt.. the entire ride home it wasnt. the next day it popped on immediately.
Old Sep 28, 2008 | 07:57 AM
Marc_H's Avatar
Do you have a spare tire in the trunk? Does it have the TPMS sensor in it? Did you check it as well?
Old Sep 28, 2008 | 08:30 AM
invasion08's Avatar
Did you check your tire pressures? If they all are set at 32 psi and the light still comes on then one or more tpms is bad.
Old Sep 28, 2008 | 03:02 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah I would run about 34 or 35 and I think sometiem you have to drive it over 25mph to shut if off if ur still under 30 psi it most likely will b on still becuase it is still considered low
Old Sep 28, 2008 | 10:24 PM
D R ii F T
thanx alot guys i put my pressure up to 34 psi in each tire and no light since, my avons do say max 35 but they are doing just fine
Old Sep 29, 2008 | 09:36 PM
read the quote in my sig
Old Oct 29, 2008 | 07:08 AM
D R ii F T
your sig does make a wonderful point indeed but when i bought my 8 at a private sale in NY, the guy had spilled something on it and as u opened the cover all the pages were beyond unreadable. i just havent gotten around to getting a new one from my dealer yet.
Old Oct 29, 2008 | 09:43 AM
Put them around 32-33.
34 is a bit too much. your car will lose some traction, not good.
Old Oct 29, 2008 | 10:10 AM
bsteimel's Avatar
Nice !!!
you can find your owners manual in pdf form on the mazda website. Its in the owners section. Your tires should be all set to 32 psi when cold. The light will stay on for about 15 minutes of drive time.
Old Oct 29, 2008 | 10:45 AM
dothackRAVE's Avatar
<3 Rotary
Unless he's autocrossing his way to work, it doesn't really matter.
Just slightly more wear in the center of the contact patch.
zoom44
General Automotive
Nov 16, 2015 11:38 PM
Hiroshima_RX
Sep 21, 2015 06:28 PM
djp6783
Sep 19, 2015 12:12 PM
erikcamacho15
Sep 12, 2015 11:23 AM
