Im dying to get this fixed - Flipkey for my 2004 RX8
Old Sep 23, 2008 | 05:42 PM
wonderful-life's Avatar
Hello guys, I have a RX8 in Sweden, and I saw that some of you made a own flipkey to your rx8's. And im very intressted in this.
I called the Mazda RX8 service in Sweden, and told them that i wanted a flipkey for my rx8 2004, and they just laughed They said its impossible, there is no way that you can build a working flipkey programmed to your 2004.
Now i want to show that bastard, and shut him up. But what do i need? I heard that the hardest part was the keycut, what exactly is a keycut? And its pretty easy to get it programmed right?
Will this work? -- >http://cgi.ebay.com/ebaymotors/NEW-0...mZ300261060193
Thanks for all help!
Old Sep 25, 2008 | 12:43 AM
Eight's Avatar
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-code-your-new-key-yourself-15244/
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-code-your-own-key-remote-43873/
Old Sep 25, 2008 | 05:28 AM
I dont mean the programming, i want to know what key i should cut and put into my new fob? They key im currently using or the service key?
Old Sep 26, 2008 | 02:45 AM
Eight's Avatar
You don't cut the key and stick it on to the new one.
The OEM flip key thats on your ebay link has an "uncut" key inside, and it should be the exact same size as the keys you currently have ( the blade part). Just bring both the uncut and cut key to a locksmith to make a copy.
A guy on one of the thread got his copied at Home Depot, I used to get my car keys copied at Lowes.
Also your going to need two of your original keys to program your new flip key, if i read those thread correctly.
Old Sep 26, 2008 | 06:33 AM
Let me see if i got this right, when my flipkey arrives from Ebay, I take that one and my current rx8key to a locksmith to copy it.
I have to make a copy of this key right http://www.msprotege.com/members/Cap...5/key%20gb.JPG ? And then they put the copied key into my flipkey?
Yes i have tvo orginal keys, so i dont need mazdas help with programming right?
Thank you
Old Sep 27, 2008 | 01:40 AM
Eight's Avatar
Yes the flip key should have an uncut key blade inside, and it should be the same size as the picture. your gonna need two original "coded" keys (not the service) to make the car learn the new flipkey and then, go on with the programming for the remote.
Your rx8 came with remote lock/unlock right? since I'm not really sure of the EU options, I only got 2 flipkeys from the dealer (USA), but it seems like you guys get 3 keys? Master, spare, and service? and I guess a remote fob?
I'd re read the other threads just to be certain. Can anybody else confirm what I said?
Old Sep 27, 2008 | 07:55 AM
Yeah, i have two original coded keys. Thats right, i got one master, one spare, and a service key, and i also have two remote fobs with lock/unlock, trunk opener and panic button.
So I have to make a copy of my master key, and then put it into my uncuted flipkey?
Old Sep 27, 2008 | 11:18 AM
ShellDude's Avatar
weeeeeeeeee
Here's my contribution to this search challenged thread
https://www.rx8club.com/showpost.php...1&postcount=12
Old Oct 14, 2008 | 05:48 PM
My RX8 is from Germany and its a late 2003 modell. I think I know what the problem is, US remotes doesnt work with EU cars simple as that. My current remote has 4 buttons, lock, unlock, trunk release and larm off botton, but the US model has the panic button instead of our "larm off" botton. What year are your rx8 from?
Old Oct 15, 2008 | 12:19 AM
Rai's Avatar
Rai
Tyler
wonderful, yes it is so, You can not use US keys for European version RX-8.
And by the way the US model key with panic button won't fit to your key wich is with alarm off key. I bought mine key on ebay from England, but it was used and it was with alarm key off.
I found one on Ebay here you can buy it, but I am surprised that it is so cheap, i bought mine for 40 euro and it was used:
http://cgi.ebay.co.uk/GENUINE-MAZDA-...d=p3286.c0.m14
Old Oct 15, 2008 | 12:22 AM
volcomx31's Avatar
Silver Power
it can be done!
Old Oct 15, 2008 | 09:42 AM
So does the UK remote works with all european RX8, I dont want to buy another remote which wont work again. Can you please give me ur visteon number for the UK remote?
And I also what to know what modell your rx8 is from and what country it has been sold to. Many thanks.
Old Oct 16, 2008 | 02:24 AM
Rai's Avatar
Rai
Tyler
I am now at work, but when I will be at home I will watch what for number I have.
By the way I have 2004 year and bought it from Germany. the key visteon nr. wich I bought from UK, was equal what I had.
Old Oct 16, 2008 | 08:53 AM
Must the visteon number match exactly for working with the car?
Old Oct 17, 2008 | 04:52 AM
Rai's Avatar
Rai
Tyler
My visteon nr. is 41844.
Somewhere I read that there can not be various numbers and I know for sure that if you got exactly the same nr. then it will work 100%.
Old Oct 18, 2008 | 07:45 AM
But the problem is that there are no flip keys with visteon no.41844
Old Oct 18, 2008 | 09:44 AM
Rai's Avatar
Rai
Tyler
right, there aren't, but why do you need a flip key, do you have the original key too as a flip key?
Old Oct 19, 2008 | 12:38 PM
So you have checked that out? There are absolutly no flip keys with that Visteon number?
I do have the orginal remotes and keys, but I really liked the flip key.
I managed to code the key itself, but I couldnt program the remote. Thats all.
Old Oct 19, 2008 | 01:26 PM
ShellDude's Avatar
weeeeeeeeee
my original visteon # is 41848. If yours is not the same and you're certain that you're performing the binding process properly then the only thing we can conclude is that they are incompatible...
My best guess is that Mazda swapped out the components at some point during the 2004 rollout. This is also probably why no one will openly market a 2004 flipkey...
What is your cars manufacture date? Mine is Nov 2003 if memory serves correctly.
Old Oct 28, 2008 | 09:56 AM
Rai's Avatar
Rai
Tyler
wonderfull - yes there aren't any...
So we must stay with the old fashioned key...
Old Nov 4, 2008 | 05:56 PM
So your orignial visteon # is 41848 and also ur flip key has the exact same visteon number?
Old Nov 4, 2008 | 09:18 PM
ShellDude's Avatar
weeeeeeeeee
My original key's visteon # is 41848.
My flipkey does not have a visteon nor was 41848 listed as a compatible number for it.
Old Nov 4, 2008 | 10:01 PM
InfiniFC's Avatar
Rotarydude
Unhappy Can't program my new flipkey...
I just recently picked up a used RX8 with a late 03 build date. I got a brand new blank (flipkey style) from the dealer, and have two programmed keys (black head). For the life of me, I cannot get my new key to program. I've tried all the techniques that seem to work for most people but so far no luck. I even removed the key chains, and keyfob on the new flip key thinking that might be causing interference. Everytime I get to the new key the icon just flashes fast.
Oddly enough, I have been able to get the remote working like a champ. That was cake compared to progamming the key.
Is it possible that keys can go bad or be different? From what I've been reading, all the keys should be the same as far as coding right? The only other thing I could think of is that the PCM is maxed out on keys assigned. Is it possible to tell if your car/PCM is maxed out with 8 keys assigned? Is there required wait time before trying to program the key again?
I've been reading up on all the related threads by searching, but none of the threads I found go into detail around this area.
Thanks in advance!
Old Nov 4, 2008 | 10:12 PM
ShellDude's Avatar
weeeeeeeeee
Sounds like you know as much about the process as I do. The only difference is the results. I spent 10 minutes binding the key and remote on my flipkey.
Looks like I got lucky. A number of people with build dates around the same time as mine have been met with failure, although it seems to be more often the remote they have problems with, not the actual key.
Old Nov 4, 2008 | 11:06 PM
InfiniFC's Avatar
Rotarydude
Aww shucks... I was hoping this would be easy as most people described. Seems the easiest things always ends up being twice as hard. Gosh darn it to heck.
Talking with a nearby service department at a local dealer, they were saying that programming Mazda keys are tough. That they charge so much for labor as a flat rate because programming can take anywhere from 5- 45 min or so using the WDS system. (So they say...)
I ordered another blank from Ebay , hoping this will shed some positive results. Wish me luck!
Thanks for replying ShellDude.
