How to remove shifter knob?
Old Dec 1, 2003 | 03:35 PM
sferrett's Avatar
Whaaaa?
Shifter **** thread specs?
Has anyone removed the shifter **** on their 8 yet?
I just got a new shifter **** for my Jeep and it just struck me that it may be appropriate for the 8... I haven't tried removing the **** yet so I thought I'd see if anyone else had already and if there were any gotchas or so forth...
Simon.
Old Dec 1, 2003 | 03:36 PM
Zio's Avatar
Zio
美浜ー先輩??!
I thought you just unscrew it??
Old Dec 1, 2003 | 03:39 PM
sferrett's Avatar
Whaaaa?
That may be the case - I haven't even tried yet (I just got the idea to do it now, and I'm at work so I can't rush out and start tinkering on the car) - I thought I might get a possible head-start on any problems I might encounter if anyone else had removed it.
Old Dec 1, 2003 | 03:57 PM
Rx-Appreci-8's Avatar
sferrett
I had mine off the other day. The manual shifter **** on the RX-8 simply unscrews. Lefty-loosy
Old Dec 1, 2003 | 08:42 PM
sferrett's Avatar
Whaaaa?
Ok so the good news is it just unscrews...
The bad news is the thread on this shifter I have isn't the same pitch (or something) as the one on the shaft.
Does anyone know what the thread size/pitch is on the shifter? The one I has a coarser thread - my guess is one's metric and one's standard, but I dont know enough about threads to know if there's some kind of coil/insert I can get to change it. The **** I have has a 12mm hole in it and comes with screw in coils to change it to 10 and 8mm - the 10mm one seems to be the right size but the thread is wrong...
Simon.
Old Dec 1, 2003 | 08:52 PM
Tamas's Avatar
Registered Lunatic
Pretty much every thread on the RX-8 is metric. Yes, you probably have a non-metric thread on the other ****.
I can't help you with the thread size of the RX-8 **** though... but if you take it off, you can get the thread measured in a Home Depot or Orchard Supply I think.
Old Dec 2, 2003 | 01:12 AM
Nubo's Avatar
Lubricious
Simon.
The shifter threads for RX-8 are the same as for Miata - 10mm diameter with 1.25mm thread pitch
Here's a page that offeres various ***** and also just the inserts if you want to "roll your own"
http://www.knobmeister.com/DirectorPage.htm
Old Dec 2, 2003 | 09:43 AM
MyRxBad's Avatar
Fb's rock!
Simon.
This is good news. :D
Old Dec 2, 2003 | 01:47 PM
Haze's Avatar
This is a little off point, but my whole shifter has a tendancy to rotate while I'm moving it from gear to gear (6 speed obviously). Does anyone else's shifter do this, or is the shifter shaft supposed to be held in place? It seems odd to me that it would rotate around while I'm driving. Any answer is appreciated - Haze
Old Dec 2, 2003 | 01:58 PM
sferrett's Avatar
Whaaaa?
Is just the **** rotating, or the whole shaft?
If it's just the ****, then I'd suggest screwing it on a little tighter. The shaft should not rotate (at least, mine doesn't - nor has any other car I've owned)
Old Dec 2, 2003 | 02:05 PM
Haze's Avatar
Whole shaft.
It's been doing it since I bought the car. Well, looks like I finally found something that I should talk to the service department about. I just assumed that it was weird, but that they all did that. Thanks for the answer.
Old Dec 3, 2003 | 12:14 AM
sferrett's Avatar
Whaaaa?
How much does it rotate? I had a test of mine tonight on the way home and I'd say it has about 1/4" of 'turn' in the shaft - more of a rotational play though. It definately doesn't twist around though, just back and forth by a small amount.
Old Dec 3, 2003 | 03:00 PM
wakeech's Avatar
mostly harmless
Originally posted by Haze
Whole shaft.
wtf???
Old Dec 22, 2003 | 05:58 PM
sferrett's Avatar
Whaaaa?
OK - the deed is done. A 10x1.25 thread tap did the trick.
Cheers,
Old Dec 22, 2003 | 08:45 PM
Jag's Avatar
Jag
Institution Escapee
Ouch....that just doesn't work for me, not the right style to match the interior of the 8, but as long as you like it thats all that matters.
Old Dec 23, 2003 | 03:40 AM
sferrett's Avatar
Whaaaa?
Yeah I know it looks clunkey, which is OK by me at the moment. The good news is it screws right off when i get sick of it!
Old Dec 23, 2003 | 11:06 AM
MyRxBad's Avatar
Fb's rock!
Your a "rotary-holic" (aka rotorhead) and you took off the rotor shapped shift-****? Hmmm....
Old Dec 23, 2003 | 11:27 AM
sferrett's Avatar
Whaaaa?
None of my other rotary powered cars have rotor shaped shift-*****... Either way I thought it was a little different and somewhat amusing.
Interestingly enough though I did notice the rx8's shift **** had started to wear - the silver plastic around the edge on one side has worn down to the clearish plastic underneath. This is with about 6200 miles on the clock...
Old Dec 23, 2003 | 11:50 AM
M-ster's Avatar
Whole shaft.
I use to have a Miata, if alot of the things going around in the transmission area are similar to the 8 then, this might help a little.
What's in the pix is basically the shifter being just lifted up/away from the turret. You see that metal pin on the edge of the opening (I've name it MALE), that pin will go into a slot which (I've name it FEMALE) can't be seen from this angle, the slot is on the back of that pivot. When the shifter is in place, the male and female meets thus limiting the travell/rotating of the shifter. The slot is cushioned with a piece of hard plastic. My guess is that female/plastic part is missing or broken. My was broken into small bits and pieces all over in the turret. I think you got to be careful when unscrewing the shift **** off the shifter, some ***** are over tighten, and when you use too much force turning the ****, you could be putting alot of stress on that plastic ...what ever you call that female parts.
This experience was from my Miata's day, I could be wrong.
Old Dec 23, 2003 | 05:57 PM
WHealy's Avatar
Mr. Blue Man
Just took mine off. Man you could loose a couple pounds here huh?
Old Dec 24, 2003 | 12:06 AM
Haze's Avatar
Full 360's around and around and around as much as person could want. I still have to get it to the dealer, but it's going to go.
Thanks for the shifter to tranny info M-ster. I was sort of curious as to what kind of problem I was looking at here to fix this, and it is a help to know just to get a sense of how long they will need to fix it. Many thanks to all - Haze
theblinkof
Oct 4, 2023 05:24 PM
RX8mzda
Oct 1, 2015 10:17 PM
Racingjunkie
Sep 29, 2015 05:05 PM
Learners_Permit
Sep 27, 2015 07:38 PM
