How to lower the turn signal blink rate?
Old Sep 14, 2008 | 03:36 AM
k8sp3r's Avatar
Does anyone know how to lower the turn signal blink rate? A buddy of mine just installed new LEDs for the turn signals and they blink too fast, gets annoying after awhile. Help will be most appreciated...
Old Sep 14, 2008 | 03:40 AM
StealthTL's Avatar
LEDs have very little current, which causes the rapid cycle.
Most LED kits come with resistors that fit in parallel (not series) with the bulb, and put load on the flasher.
Alternatively, if you can find the flasher unit (I'n not sure where it is) you can replace it with an 'electronic/trailer' one - they flash at the same rate no matter how many, or few, bulbs in the circuit.
S
Old Sep 14, 2008 | 12:19 PM
hakuna matata!
http://cbrworld.net/forums/thread/141166.aspx
Old Sep 14, 2008 | 01:27 PM
Thanks Stealth... I didn't know you could buy an eletronic trailer flasher.
Old Sep 14, 2008 | 01:29 PM
laythor's Avatar
I zoom therefore I am.
I use http://www.stealthauto.com/Departmen...lth-Bulbs.aspx for my flashers
Old Sep 14, 2008 | 05:50 PM
NgoRX8's Avatar
flasher or load resistor.
Old Sep 14, 2008 | 07:19 PM
greg985's Avatar
The 337
this is what you need
http://kalecoauto.com/index.php?main...&products_id=6
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
PTQLam
Sep 5, 2015 01:14 PM
