Another New Engine!!!
Old Sep 11, 2008 | 05:53 PM
WTBRotary!'s Avatar
Drummond Built
Exclamation Another New Engine!!!
LOL so i was driving my RX-8 and noticed it was leaking oil... not wanting to look and see wtf was up and thinking it would be easier, i took it back to the Mazda Dealer to have it looked at. Turns out they didnt tighten all the bolts and oil was gushing out, so the seals are **** again and their getting me a WHOLE NEW ENGINE again... this sucks, i only had 150 miles on the first new engine and now i dont get my car again for a week while it gets another new engine... then i gotta start all over on the break-in period again... sigh...
Old Sep 11, 2008 | 06:07 PM
expo1's Avatar
He's as bad as Can
How long did you continue you run the engine knowing something was wrong.
Old Sep 11, 2008 | 06:15 PM
WTBRotary!'s Avatar
Drummond Built
it just happened today...
Old Sep 11, 2008 | 06:29 PM
expo1's Avatar
He's as bad as Can
I didn't ask you what day this happened. Lets try this a second time.
You posted this
How many minutes did you continue to run the engine knowing something was wrong till you ended up at the dealership.
Old Sep 11, 2008 | 06:35 PM
WTBRotary!'s Avatar
Drummond Built
lol i had to drive for about 3 hours so around 3 hours TOPS, probably more like an hour, i had to go to my mothers work, then i noticed and took it back... so anywhere from an hour to 3
Old Sep 11, 2008 | 07:48 PM
alnielsen's Avatar
Let me get this straight, you drove it back to the dealership after you found out (in your words) oil was gushing out?
Old Sep 11, 2008 | 08:10 PM
WTBRotary!'s Avatar
Drummond Built
not gushing... leaking a decent amount... before i could go to the dealer i had to go to my mothers work first, thinking it would be fine...
Old Sep 11, 2008 | 08:46 PM
expo1's Avatar
He's as bad as Can
So I guess next time when your car is leaking a vital fluid you will park it and get a tow. Doing that could could have saved the engine.
Old Sep 11, 2008 | 08:53 PM
Easy_E1's Avatar
Don't get the "Expo1" going. He can bite.
Old Sep 11, 2008 | 09:44 PM
WTBRotary!'s Avatar
Drummond Built
lol its no biggie... i get a whole new engine... for free... again... not like it was my fault anyways for not tightening the bolt... yes i probably should have taken it to the dealer first, but its not like i have to use the same engine. i get a whole new one for free...
Old Sep 11, 2008 | 11:06 PM
exsequor's Avatar
wipe me down
I think they're being hard on you because any self-respecting lover of his/her car would not drive it if it was leaking oil in any way.
Old Sep 11, 2008 | 11:48 PM
WTBRotary!'s Avatar
Drummond Built
yes yes i love my car very much... i didnt know it was leaking THAT much, just a decent amout like a few drops or so, i assumed it would be ok... and yes i know what assume means... lucky me tho it wasnt my fault... so new engine for me again...
Old Sep 12, 2008 | 06:39 AM
expo1's Avatar
He's as bad as Can
Was this ' few Drops ' noticed while parked or with the engine running?? You do know that when the engine is running the oil is under pressure. A few drops under a parked car can be a major leak while running. Since the total oil capacity of an RX-8 is almost 8 quarts you must of had a larger leak. I would be sure to thoroughly check out the car after you get the 2nd engine and check the oil daily for the first few weeks.
Old Sep 12, 2008 | 06:57 AM
bse50's Avatar
#50
Amen, mostly because a new engine is an expense for mazda.
Reducing wasted money would help the rotary engine imho, especially in third world countries like mine, where there are no shops that can rebuild it.
Mazda dealerships don't even decarb engines here, they just change them.
waste of money.
Old Sep 12, 2008 | 11:26 PM
WTBRotary!'s Avatar
Drummond Built
yeah well im for sure gonna check the oil daily and make sure everything is running fine... i dont want my car back in the shop again...
Old Sep 13, 2008 | 04:52 AM
XRX8X's Avatar
more then a Mazda
question for expo 1. 2004 6spd. 55,000 miles and just had the engine replaced.after driving for about 20 minutes and came back out from the mall the engine sounded different and being low on gas i topped her off .when i got home it was still sounding a little off so i checked under the hood to find a vac.hose off.it came off while driving and burnrt a little on the alt pulley.i cut it off where the hole was on the hose and reinstalled it.now this was at 11pm at nite and i can't sleep to good .do you think they put in this reman engine with problems to be found out later or is my dealer to dumb to fix it right the first time?now for the little history.oil was changed every 3,500.wro has replaced the oil pan,front and rear tail lights and headlights,transmission,water pump,battery ,starter,clutch pressure plate and throw out bearing, spark plugs four or five times, and the cat as well!all recalls that made the car run and sound different every time they retuned it.untill the engine failure what the hell is going on on?
Old Sep 13, 2008 | 12:31 PM
expo1's Avatar
He's as bad as Can
I don’t think dealership employees are dumb, I just think they don’t care. Think about it you drive your 8 for thousands of miles, they around the block and they still try and make you feel like you know nothing about how your car is supposed to run. This might be a stereotype but I feel the people that work in the service area also tend to not be as customer focused as other type of workers so they just don’t know how to relate to people.
The Reman cam in on a pallet and the shop put it in. they have no clue has to how it will run in your car. They are trusting the factory that did the rebuilt did it right. I didn’t trust the dealership or a Mazda Reman and chose to have my rebuilt done by Mazda enthusiast (Mazmart) and installed by someone that owns his shop, not just punching a time clock. So far that looks to have been a good choice. How has it been running since you put the hose back on? I might also think about getting a baseline compression test done.
Old Sep 15, 2008 | 03:42 AM
Jim Chen's Avatar
Autobahn 8
Speaking of Engines, since mine is going to die soon...can anyone tell me how much a new one will cost and how much will they charge for labor as well.
Old Sep 15, 2008 | 08:15 AM
greg985's Avatar
The 337
I think its around 5,000 USD for a new one, correct me if I am wrong
Old Sep 16, 2008 | 03:29 AM
Minotavr's Avatar
Less Fast, More Furious
Ha ! From where I am it would be 5000 Euros
Old Sep 24, 2008 | 10:03 PM
JGR4444's Avatar
GR
dealership quoted me 7 grand when i had it in last...
i bought a used one with 20 k on it that was taken from a totalled rx8 and im in the process of putting it in now...
so far im only $1800 in
Old Sep 25, 2008 | 05:28 PM
Motomouse's Avatar
expo1 when did you rebuild your engine. I was reading a few months ago that you pass magic 100k on your odo ?? Am I missing something?
Old Sep 25, 2008 | 05:43 PM
expo1's Avatar
He's as bad as Can
I was having a oil leaking issue at the track, around town things were ok. But 4 x 25 minute runs @ high RPM on a track like Watkins Glen was a bit much for her. Paul from Mazmart had a few rebuilds around so around 110,000 I bought one and had Jim from JPR do the install. There is a very good THREAD out there with photos from Mazmart when they took apart my engine. Could I have put off the rebuild? Paul from Mazmart thought so. Could I drive 80 minutes on a track, no. So I had an elective engine replacement done around 110,000 miles. My 8 is no longer my DD so it will be a while till I hit 200,000
Old Sep 26, 2008 | 06:24 AM
XRX8X's Avatar
more then a Mazda
well i took the car to another dealer and they said the cat. is shot again i need to spend $1600.00 for a oil pump and another $300.00 for a port motor that seemed to fail after the engine install!i am really bothered that all these swapped out conponents are failing one by one.whats next the alternator then the water pump?if i had broken these things myself i would not complain i just feel it is to odd that after a engine replacement everything they touched is going into the *******.without reason.just totally fu*&#@.and i don't like it.
Old Sep 28, 2008 | 03:48 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah i think i would have went straight to the dealer when i saw it was leaking but at least you are getting anew engine
mr. GrandGame
Sep 9, 2025 10:41 PM
vapor2
Nov 3, 2020 03:38 PM
badinfluence
Aug 31, 2015 11:51 AM
cschoeps
Aug 6, 2015 12:44 PM
Rx8Lovin
Jul 25, 2015 08:39 PM
