Parking lights...
Old Sep 11, 2008 | 11:56 AM
terreezzy's Avatar
Parking lights...
my headlights are HID 6000k and i was wondering how to changed my parking lights to the same color...
I've did some searching and found out that the maplight and parking light uses the same bulb?
Old Sep 11, 2008 | 11:59 AM
StealthTL's Avatar
So what is your question?
S
Old Sep 11, 2008 | 12:23 PM
Krazed_Rx8's Avatar
I think he wants all his lights the same color/brightness?
Old Sep 11, 2008 | 01:10 PM
terreezzy's Avatar
lol my question was how would i do it
Old Sep 11, 2008 | 01:14 PM
NgoRX8's Avatar
you change them out
go look for some 194s that match. it'll be hard to find an exact color match though. and you'll probably have to experiment in that sense.
Old Sep 11, 2008 | 01:23 PM
StealthTL's Avatar
Cool
You can install your new bulbs fairly easily, from the engine compartment - nothing to unscrew or unbolt.
The bulbs enter the housings from the side, not the back, so take off the fusebox lid and slip your hand in - you'll feel the bulb holder. A quick twist and change the bulb. Make sure the bulb is well seated before you put it back - you don't want to have the bulb fall out into the housing (the only way to get it out is to pick the car up and shake it, hood end up! )
If your hands are 'petite' you can do the passenger side this way too, if you have huge mitts you can give yourself more room by taking the computer lid off.
S
Old Sep 11, 2008 | 01:29 PM
NgoRX8's Avatar
yup, my hands are small and it's a very tight fit on the passenger side. using only my pointer and index fingers to tighten it.
wow, i'd like to see that. haha
Old Sep 11, 2008 | 01:48 PM
terreezzy's Avatar
another question the research i did was on a 2004 rx8 would it be the same as my 2007 one? and if it is 194s would the ones from rx8strakes.com fit since it's the same as the map lights
Old Sep 11, 2008 | 02:07 PM
NgoRX8's Avatar
the 2004 bulb lighting should be the same as the 2007 lighting specs. the rx8strakes map lights should work as long as they're 194 bulbs and not just 194 bulb holders. contact them just for assurance since they don't show pictures of the bulbs themselves.
Old Sep 11, 2008 | 05:23 PM
Kris's Avatar
I have the 5 LED Refractor style 194's in my parking lights, there a little more blue than my HID's but they are the closest i could have gotten.
pjwermuth
Sep 28, 2015 11:36 PM
Tweaked Tay
Sep 25, 2015 07:54 AM
Rx8_412
Sep 24, 2015 08:51 PM
