DIY: Diagnostic Outputs
Old Sep 9, 2008 | 03:35 AM
Jon316G's Avatar
Grasshopper
Here are some random diagnostic outputs to use while troubleshooting.
Let me know if I missed any outputs that can be useful and I'll update this post.
Instrument Cluster:
  1. Put the key in the ignition
  2. Push and hold the odometer button
  3. Turn the key to the 'ON' position (do not start the car)
  4. Continue to hold the odometer button until 'test' appears in the lower right corner
  5. Once 'test' appears, you can release the button
  6. Now push (not hold) the odometer button to scroll through various numbered options
  7. Stop when you reach the desired output
  8. After a full second the output signal should toggle (ex: light illuminates, gauge sweeps)
    • Some have an on/off switch (ex: Buckle switch changes state when the seat belt is buckled)
  9. To exit from the output diagnostic, simply turn the key to the 'off' position and back on.
Here is a list of all the outputs and what they mean:
01 = Buckle switch
04 = Door switch
08 = TNS relay
12 = Speedometer
13 = Tachometer
14 = Buzzer
16 = Fuel-level warning light
18 = Ignition key illumination
22 = Fuel gauge sender unit
23 = Fuel gauge
25 = Water temperature gauge
26 = Odometer tripmeter, warning and indicator light
28 = Oil pressure gauge
31 = Key reminder switch
55 = Dimmer switch
Speaker Inspection (Test Tone)
  1. With the audio power on, press the 'POWER' button and simultaneously press the 'AUTO-M' button for roughly 1 second.
  2. It will generate a test tone in the following order:
    1st- Front driver-side door speaker and tweeter.
    2nd- Front passenger-side door speaker and tweeter.
    3rd- Driver-side rear speaker.
    4th- Passenger-side rear speaker.
LCD Inspection:
  1. With the audio power on, press the ‘POWER’ button and simultaneously press the ‘SEEK’ button for approximately 1 second
  2. All the LCDs will illuminate. Inspect for any bad characters.
  3. Turn the audio off or the ignition switch to the ‘LOCK’ position to stop the diagnostic assist function.
Button Inspection:
  1. With the audio power on, press the ‘POWER’ button and simultaneously press the ‘CLOCK’ button for approximately 1 second
  2. Press all the buttons. A buzzer sounds with each button pressed.
Temperature Control ****:
  1. With the audio power on, press the ‘POWER’ button and simultaneously press the ‘SCAN-UP’ button for approximately 1 second
  2. "A/C TEMP" should appear on the left side of the LCD display and a number from 0 to 16 on the right.
  3. The number advances in increments of 1 as you turn the temperature control ****
  4. Turn the audio off or the ignition switch to the ‘LOCK’ position to stop the diagnostic assist function.
Radio Reception Condition Inspection:
  1. With the audio power on, press the ‘POWER’ button and simultaneously press the ‘PRESET 2’ button for approximately 1 second.
    • Even if the system is normal, radio reception may be difficult depending on where the system is inspected (indoors/outdoors, or conditions at the location). Before inspecting the system, verify that radio reception is adequate
    • When inspecting, select a frequency band (radio station) with the best reception
      LEV- 5 through LEV- 9 = Antenna, antenna feeder and base unit are normal
      LEV- 3 through LEV- 4 = Change the frequency (radio station) and inspect again
      LEV- 0 through LEV- 2 = Malfunction present
  2. Turn the audio off or the ignition switch to the ‘LOCK’ position to stop the diagnostic assist function.
On-Board Diagnostic (Audio)
  1. Turn the ignition to the ‘ACC’ or ‘ON’ position
  2. While pressing the ‘POWER’ button, simultaneously press the ‘AM’ button and the ‘TAPE/MD’ button for 2 seconds or more
    • If several DTCs are in memory, they can display using the ‘SEEK’ button
    • If no DTC is stored, no codes will be displayed
  3. To stop the on-board diagnostic test mode, turn the ignition switch to the 'LOCK' position
Identify the device and supplier codes by referring to the LCD display.
.1 09: ER20
__|_______|___________|_
Supplier..Device...........DTC
Supplier Code:
1 = FMS audio
2 = Panasonic
3 = CLARION
Device code:
00 = Cassette Deck
03 = CD player
05 = CD Changer (external)
06 = CD Changer (upper module)
07 = MD player
09 = Base Unit
10 = CD player system MP3 operation
Memory Clearing Procedure
1. Start the on-board diagnostic test mode
2. While pressing the ‘POWER’ button, simultaneously press the ‘AUDIO CONT’ button for 2 seconds or more.
3. To stop the on-board diagnostic test mode, turn the ignition switch to the ‘LOCK’ position
DTC Table (Audio System)
09: Er22 = Base unit (peripheral circuit for tuner)
09: Er20 = Power supply circuit to base unit
00: Er10 = Cassette deck communication circuit system
03: Er10 = CD player communication circuit system
05: Er10 = CD changer (external) communication circuit system
06: Er10 = CD changer (upper module) communication circuit system
07: Er10 = MD player communication circuit system
03: Er01 = CD player system
03: Er02 = CD player system
03: Er07 = CD player system
00: Er01 = Cassette deck system
00: Er03 = Cassette deck system
00: Er04 = Cassette tape system
05: Er01 = CD changer (external) system
05: Er07 = CD changer (external) system
06: Er01 = CD changer (upper module) system
06: Er02 = CD changer (upper module) system
06: Er07 = CD changer (upper module) system
07: Er01 = MD player system
07: Er02 = MD player system
07: Er07 = MD player system
07: Er08 = MD system
10: Er01 = CD player system MP3 operation
10: Er02 = CD player system MP3 operation
no Er = No DTCs stored
Immobilizer System (DTC Inspection)
  1. Turn the ignition switch to the ‘ON’ position
  2. Verify the security light state.
    • If there are any malfunctions:
      • After any malfunction is detected, the security light will function as follows for approximately 1 min.
        DTC 16 and lower: Flashes
        DTC21 and higher: Illuminates
    • If there are no malfunctions:
      • The security light illuminates for approximately 3 seconds and goes out.
  3. When any malfunction has been detected, read DTCs via flashing patterns displayed after the security light flashes or illuminates for approximately 1 minute.
    • A verified DTC is flashed 10 times repeatedly by the security light.
    • If multiple DTCs are verified, the security light displays only the smallest DTC.
DTC Table (Immobilizer System)
Security light flash pattern:
∩__∩_________ = No detected communication with the coil
∩__∩∩________ = Coil malfunction
∩__∩∩∩_______ = The key ID number data cannot be read or key ID registration error
∩__∩∩∩∩______ = The keyless control module cannot read key ID number data normally
∩__∩∩∩∩∩_____ = The keyless control module has detected unregistered key ID number
∩__∩∩∩∩∩∩____ = Communication error between the keyless control module and the PCM (no response or mismatched conditions)
∩∩__∩_________= Only one key ID number is registered
∩∩__∩∩_______ = Communication error between the keyless control module and the PCM (data transfer error)
∩∩__∩∩∩______ = ID number data in the PCM and the keyless control module do not match.
NOT ILLUMINATED = Keyless control module malfunction
Old Mar 27, 2009 | 02:57 PM
secret8gent's Avatar
the enemy in the mirror
if you wanted to be a real cool guy you could put up the airbag light flash codes here too.
regardless, nice post.
Old Mar 27, 2009 | 03:07 PM
Jon316G's Avatar
Grasshopper
I don't believe the airbag system has flash codes, but I'll look through the service manual just to be sure.
The airbag system uses a DTC code (Bxxxx) to display the error condition.
Maybe teknics can help find it (if it does exist).
Old Mar 27, 2009 | 10:57 PM
teknics's Avatar
Certified Mazda Tech
To get the codes to flash turn the key to the ON position, easiest way to show you the list of codes for me was to take screengrabs, hopefully theyre good enough i work on a high resolution so sorry if theyre huge i cropped them to what looked decent on my setup and was within file size limits of the forum. (should be 3 attached photos, this info is in the FSM just after the foreword and flowchart of the ABS diagnosis section)
also in case you dont look at the pics, the flashes are associated with their DTC codes as well so it can be helpful in diagnosing your problem.
hope 'tis helpful.
kevin.
Attached Thumbnails DIY: Diagnostic Outputs-ab1.jpg   DIY: Diagnostic Outputs-ab2.jpg   DIY: Diagnostic Outputs-ab3.jpg
Old Mar 27, 2009 | 11:22 PM
I love you Kevin
Old Mar 27, 2009 | 11:48 PM
teknics's Avatar
Originally Posted by nycgps
I love you Kevin
lmao, i just reprinted the FSM it's cool
kevin.
Old Mar 28, 2009 | 12:13 AM
kevin.
We still love you
Old Mar 28, 2009 | 06:11 AM
Jon316G's Avatar
Grasshopper
Great!
Thanks again teknics!
Old Apr 8, 2009 | 12:20 AM
Gray06's Avatar
GR8FUL
Just moved from the Canton Area, sister said it snowed there this week.
Old Apr 8, 2009 | 12:33 AM
Jon316G's Avatar
Grasshopper
Yeah... it snowed yesterday.
I hate Ohio weather.
Going from 60s and sunny to 30s and snow is frustrating.
But we're going back to mid-high 50s by this weekend.
You know how it is since you're from Canton area
Old Jun 13, 2009 | 04:38 PM
teknics's Avatar
bumping this to the top as its ridiculously useful, should be stickied/pinned, i refer people to this topic constantly.
kevin.
Old Jul 1, 2009 | 06:11 AM
robbz23's Avatar
bump again. I just got the airbag light and now i can try to figure out what it means and maybe its just a loose connection. It flashes a code for a few seconds then stays illuminated.
Old Jul 22, 2009 | 07:19 PM
Cruz-Dynamics's Avatar
hey
hows it going
ive tried putting my scaanner into the car
but it gaves me a code
i cant remember what it is
but it says that is
is unable to connect to the instrument cluster
what could be the cause??
Old Jul 22, 2009 | 07:21 PM
Jon316G's Avatar
Grasshopper
Does your scanner support CAN protocol?
Old Jul 23, 2009 | 10:14 AM
yeah
it worked before when i put it in the car
it read the codes and all
but now
i have 2 put the model and maker of the car ( something that i didnt have 2 do before) and even with that i cant read it
i also when to my frieds shop they have a snap-on scannner
and not even with that was it able 2 gain acees to the cluster
this is the code;
go155
lost comunication with instrument panel cluster (ipc) control module
Old Dec 19, 2009 | 10:14 AM
Liu Kang's Avatar
PA
I have a question, the airbag went off in my car, it was the airbag that is actually in the passanger side seat. Anyway, can I reset the AIRBAG SRS MODULE COMPUTER using the above method? How did everyone make out with this? LMK
Dan
Old Jan 5, 2010 | 04:06 PM
2SeeKU's Avatar
Aussie
.1 09: ER20
Supplier Code:
1 = FMS audio
2 = Panasonic
3 = CLARION
Device code:
00 = Cassette Deck
03 = CD player
07 = MD player
09 = Base Unit
1. Start the on-board diagnostic test more
Any reason why this wouldn't work on my '04 6 stacker?
Old Jan 5, 2010 | 04:52 PM
Jon316G's Avatar
Grasshopper
You need to have a stored DTS in order for this information to display.
Old Jan 5, 2010 | 06:02 PM
2SeeKU's Avatar
Aussie
That makes sense :D
Cheers!
Old May 24, 2010 | 03:19 PM
Geo2leo's Avatar
* If there are any malfunctions:
o After any malfunction is detected, the security light will function as follows for approximately 1 min.
* If there are no malfunctions:
o The security light illuminates for approximately 3 seconds and goes out.
* A verified DTC is flashed 10 times repeatedly by the security light.
* If multiple DTCs are verified, the security light displays only the smallest DTC.
∩__∩∩∩∩∩∩____ = Communication error between the keyless control module and the PCM (no response or mismatched conditions) ←←←←←←←← THIS IS WHAT MY 04 MT is showing, and it does not start...... what can i do?
Old May 24, 2010 | 04:32 PM
Jon316G's Avatar
Grasshopper
You might want to have the dealer inspect this one.
If the keyless control module needs replaced, you'll also have to register the keys and transmitter ID code.
I can link you to a shop manual to follow if you feel like tackling this yourself, but the dealer might me able to tell you for sure if its the keyless control module that is defective.
Old May 25, 2010 | 08:05 PM
Geo2leo's Avatar
great post. Can you please send me that link, much appreciated..
Old May 25, 2010 | 08:08 PM
Jon316G's Avatar
Grasshopper
http://isomerica.net/~fluffy/Ren/RX8%20FSM/
What you're looking for is in the "Body" section.
Old Jun 22, 2010 | 06:19 PM
musturbo's Avatar
under pressure
FL
WOW huge help I just got a check engine light on my 07. Now I can oull the code and figure it out. Thanks!
Old Jun 13, 2011 | 10:59 AM
RX8 Newby's Avatar
How did you fix this problem? I've got the same problem. The link doesn't work anymore
Thanks.
Geo2leo is offline Report Post Reply With Quote
