30k miles service DIY help
Old Sep 3, 2008 | 01:56 PM
db_8's Avatar
Exclamation 30k miles service DIY help
will be doing the 30k miles service myself:
oil change
trans/diff fluid change
brake fluid change
check plugs & coils
zoom power engine cleaner
check/clean battery
then send out for tire rotation/alignment
question is: in what order would all this be done best? this is my first time doing this btw hope everything goes smooth.
Old Sep 3, 2008 | 06:40 PM
invasion08's Avatar
It does not matter waht order you do this in. I would buy new coils and spark plugs. You can get the coils pretty cheap from www.waynemazdafactoryparts.com. And for the spark plugs go to www.autopartswarehouse.com.
Also you should change your anti freeze coolant since it should be cahnged every 2 yrs
When you change the spark plugs make sure you put alittle anit-seize on the threads
Old Sep 6, 2008 | 11:51 AM
tunerwannab's Avatar
I would do the cleaning then do the plugs a couple days later.
Billy Marcial
Mar 1, 2018 06:50 AM
Ugafan97
SE For Sale/Wanted
Apr 28, 2016 03:35 PM
Solidtrance
22
Sep 4, 2015 12:47 PM
EfrainOlivares
Aug 14, 2015 06:17 PM
akagc
Aug 11, 2015 07:07 PM
