Esmeril Dyno - Out of the box.
Old Aug 27, 2008 | 10:24 PM
ChrisRX8PR's Avatar
13B-RE
In lieu of recent happenings and the fact that we had promised a baseline dyno a long time ago we realized that we owed it to our current/future customers to do a baseline dyno and that the fact that we were very busy developing new products and manufacturing existing ones was no excuse for not having this. We made it a point to setup some dyno time with a local shop so we could give you some proof of what the kit is capable of instead of wasting time talking about the issue.
Here is the result:
366whp/265wtq
Here are the conditions for the run and below find the dyno graph:
- Completely out of the box kit with atmospheric dump.
- 13 psi.
- Esmeril Racing Ignition Upgrade Kit.
- ABS/DSC fuse pulled (all other methods failed).
- Between 40-50% humidity and 80deg.
- 91 Octane pump fuel with no additives.
Some clarifications before questions arise:
The dyno we used (the newest/nearest one to our location) was nearly brand new, just installed a few weeks ago and the dyno cell/enclosure hasn’t been finished. No extractor was set up for the exhaust gases and the rear door was unopened due to the opening mechanism not being in place yet. All these variables caused the air inside the Dyno cell to be saturated with low oxygen air(it was a cave with the exhaust facing towards the inside wall) evident by the fact that on the street the car runs at 11.5AFR with this exact setup/map/etc. and when in the dyno it dropped to 10.0-10.2AFR across the board, further dropping to a super low 9.4AFR in the 5200rpm region which was a little detrimental to the tq/hp curve (it would have been at peak from this point on but it suffered a dip in this region). Should our dyno have been well ventilated and the humidity lower (it was storming outside) we expect more can be coaxed from the set-up as it sits.
This current number, however, is more than we anticipated on this A/R turbo housing (our original promise was of 340whp at 13psi and you can see that at 8000rpm the A/R starts limiting peak power a little bit). We feel very confident that with a fully operating dyno (with some kind of airflow going through it ) the results would be even more favorable.
As a further commitment to the community we have set another date where we will go with the car to the dyno again when it is fully operational and do a full blasted run taking the Esmeril Turbo Kit to the max as it comes out of the box. We are expecting this to be within a month’s time and this time we will do whatever it takes to accomplish this.
A video of the run and a new video of the car on the street will follow soon as well.
Thanks,
Chris
Attached Thumbnails Esmeril Dyno - Out of the box.-366.07whp-esmeril-racing-dyno-2-.jpg   Esmeril Dyno - Out of the box.-img_0221.jpg
Old Aug 27, 2008 | 10:34 PM
StealthTL's Avatar
Holy Crap!111!!
S
Old Aug 27, 2008 | 10:37 PM
TopGear8's Avatar
mkuhnracing.com
It's nice to finally see some numbers. Well done.
Old Aug 27, 2008 | 10:38 PM
05rex8's Avatar
sold the 8... :(
^what he said
very nice guys
Old Aug 27, 2008 | 10:45 PM
chancejat's Avatar
Drive it like u stole it!
looks like theres a very smooth power delivery very supercharger like.....hmmmm...
Old Aug 27, 2008 | 10:54 PM
ChrisRX8PR's Avatar
13B-RE
It is smooth unde the boost curve and above it but the transition causes the tires to break loose in third from a roll when under 70deg and low humidity. Makes for a very fun ride
Chris
Old Aug 27, 2008 | 10:57 PM
NICE ~~~~~
Another option to consider ... NICE !
Old Aug 27, 2008 | 11:15 PM
Zoom zoom!
Old Aug 27, 2008 | 11:27 PM
Brettus's Avatar
Boosted Kiwi
holy horsepower Batman
Good job
Old Aug 27, 2008 | 11:32 PM
Easy_E1's Avatar
Very nice numbers!
Old Aug 27, 2008 | 11:42 PM
kersh4w's Avatar
Hit & Run Magnet
nice.
thats 2 kits that are +350whp.
put all the haters to rest. the renny is new, all it takes is time and we will see 400whp. it just takes money.
Nemesis8's Avatar
Bigus Rotus
Would be nice to see the x-axis as RPM
Old Aug 27, 2008 | 11:49 PM
ChrisRX8PR's Avatar
13B-RE
I actually have one of the runs with RPM in the X axis. Just not an original dyno file, its printed on paper. I will need to scan it and post it tomorrow morning until I can get a hold of the actual dyno file.
Thanks,
Chris
Old Aug 27, 2008 | 11:54 PM
Nemesis8's Avatar
Bigus Rotus
Good work Chris, this will be an intersting car to pull up next to on the highway I bet.
Your getting close to race specs it seems... Compare your setup to the D962R Turbo which uses a Garrett G35 Turbo, Tial 44mm external wastegate, intercooler, and larger primary injectors. Their Renesis engine produces 435 bhp, and 235 lb-ft of torque at only 9 psi of boost.
Old Aug 28, 2008 | 12:04 AM
ChrisRX8PR's Avatar
13B-RE
I've had a few encounters....mostly are followed by the "radio adjustment syndrome" where the driver of the loosing car acts like nothing happened and adjusts his radio while trying to look in that direction so he doesn't have to look at me . Very peculiar....
The D962R revs the crap out of the engine that is why it produces soo much power with so little torque.....very impressive indeed!
Thanks,
Chris
Old Aug 28, 2008 | 12:18 AM
hakuna matata!
Hot.
Old Aug 28, 2008 | 12:49 AM
morkusyambo's Avatar
Dongbag extrordinare
Sweet.
Old Aug 28, 2008 | 12:56 AM
tajabaho1's Avatar
Destroying Threads
sweet jesus mother of god @.@
Old Aug 28, 2008 | 12:58 AM
MazdaManiac's Avatar
Excellent.
I'll add it to the dyno comparo.
This is the kit with the pre-tuned Int-X?
Old Aug 28, 2008 | 01:00 AM
holy crap! Nicely done guys!
Old Aug 28, 2008 | 01:05 AM
ChrisRX8PR's Avatar
13B-RE
Originally Posted by MazdaManiac
Excellent.
This is the kit with the Int-X. It has the base map but it was tuned because the base map is meant to be extremely rich at boosts levels above 10psi for safety reasons with customer installs in case of an issue with a wrongfully installed wastegate or something of the sort. Some tuning is required to get to this but it is with what comes in the kit and nothing more.
Thanks,
Chris
Old Aug 28, 2008 | 01:53 AM
I'm also curious why you have such problems with the DSC/TCS.
I've never had any kind of interference from those systems, even at power levels substantially above this.
Old Aug 28, 2008 | 08:33 AM
ChrisRX8PR's Avatar
13B-RE
I don't know if its the same with every car. I have even seen cars with my own eyes that dyno well just pushing the button for 10sec. For some reason mine is not one of them. My system will flash the ABS light and the car will slow down after 6500rpm like I let off the gas if I just push the button for 10sec and do the run in 4th. If I do it in 3rd it doesn't do anything but the numbers are not as realistic because its suck a high ratio. It might have something to do with the 100mph mark as this is where the issues start happening. Either way pulling the fuse with the car in the off position took care of the problem for the entire dyno session.
Also, I would really like to see a chart of an RX-8 at higher than 366whp with a renesis if you have one available. It sounds awesome and might inspire some faith from the people in the forum
Thanks,
Chris
Old Aug 28, 2008 | 09:36 AM
ChrisRX8PR's Avatar
13B-RE
Dyno update!
Here is one of the runs with the RPM in the X axis. This was scanned so excuse the quality . We will update with a digital copy soon.
MM, Thanks for updating the dyno comparison thread.
It seems as if something is a little off though. On the TQ graph our curve is at all times above the mazsport kit yet on the WHP graph it never surpasses the mazsport graph(weird because we made 4whp more) and from 6000-7600 it even appears as though the mazsport was higher than ours when in that range our tq is higher which makes that impossible since higher tq at the same RPM = more hp. Our max tq should also be edited, it was 265+ not 262 as it says in the block next to the graphs.
Also, please edit our name to read Esmeril instead of Esmiril.
Thanks a million.
Chris
Old Aug 28, 2008 | 09:44 AM
maxxdamigz's Avatar
Baro Rex
Question: do you have a plot of boost vs. RPM? I see that your torque peak occurs after 7000 rpms (by my guess). Also, do you know what the SAE value was that was used? I wish my torque curve was that smoothe.
