whirring noise at neutral
Old Nov 27, 2003 | 10:51 PM
RX_Paranoid's Avatar
I just got my black on black rx8 2weeks ago. I noticed that when its at neutral, there is a humming/whirring noise which goes away when I depress the clutch. Is this normal? or should i have it looked at? I've never had this happen in other cars, so I dont know if its normal in rotaries or whatever.
Old Nov 27, 2003 | 11:40 PM
s1mike22's Avatar
normal.
Old Nov 28, 2003 | 11:57 AM
mikeb's Avatar
100% Italian
so then its not normal
have mazda check it out
Old Nov 28, 2003 | 12:32 PM
MazdaManiac's Avatar
Normal may not be the word for it.
Every RX-8 that I have driven or been exposed to makes thes same "whirring" or "grinding" noise when in neutral.
Disengaging (pushing in) the clutch stops it.
It is likely that it is the gear set rotating, though some have postulated that it is the release bearing.
If it were the release bearing, the noise wouldn't stop when you press the clutch.
To some extent, my Miata makes the same noise.
Whether it is normal or not remains to be seen.
Old Nov 28, 2003 | 01:23 PM
wakeech's Avatar
mostly harmless
look, it's an Aisin 'box based on the design for the Miata. in Miata's, there is the same whirr from the spin of the output shaft.
don't let Rikki freak you out with his horror story as he's the only one to break his transmission yet, and that's AFTER he repeatedly beat the living christ out of it (burn outs, power shifting all the way down the quarter mile, etc). i don't know why he said that, but whatev...
in any case, this has been discussed at length in many other threads. use the Search button at the top to find them, give 'em a quick read through, then add onto the end ('ressurect' if necessary) if you have anything else to add.
WranglerFan
Nov 5, 2017 09:35 AM
Mane
Nov 20, 2015 12:16 PM
nowakm99
Oct 9, 2015 07:10 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
