New Engine or Just a Rebuild? Help.
Old Aug 9, 2008 | 12:12 AM
Str8HuStLiN's Avatar
Confused here with which one I need, maybe the community could shed some light upon me:
was driving along the freeway one day, felt a loss of power so i got off the gas then pressed on it again. the car then drove sluggish from 6k rpm on up. so i cruised back home (about 20 miles) parked it for a few days. after about 2 days pass i took it for a ride to see if the problem would repeat. it did not. ever since that day there has been no problem what so ever. drives normal, no loss of power, no sluggish feeling, and pick up is back to the norm.
Car has about 77k miles on it. 2004 6spd. oil changed frequently. fully synthetic.
my car is not under warranty so a new motor would suck a$$.
research ive done:
read up on the new engine club thread
searched and read threads under "Marbles in a can" (seems similar to my problem, except i didnt hear the sound)
mostly what i was interesting in is having the engine rebuilt by CRH and possibly ported by mazdatrix if possible??
please help asap.
Old Aug 9, 2008 | 12:28 AM
mac11's Avatar
Rotary , eh?
if you are not experiencing any loss of power any more what makes you think you need a new motor?
Old Aug 9, 2008 | 12:33 AM
due to that experience i feel something is wrong because obviously thats not normal. and im the type to solve something before it goes horribly wrong and could be dangerous to myself and/or others around.
if this is a sign of a future failing engine id like to get it fixed before it fails during driving.
Old Aug 9, 2008 | 12:35 AM
mac11's Avatar
Rotary , eh?
It could have been one of 18 million things. For example the car was on the verge of overheating (was it hot outside?) and the PCM pulled timing. In that case the engine would be perfectly fine.
If you want to know about the health of your motor go to a dealership or rotary specific mechanic and have them do a compression test.
Old Aug 9, 2008 | 12:37 AM
mac11's Avatar
Rotary , eh?
It's not necessarily a sign of anything.
And a failing rotary motor won't hurt anyone. It probably won't even strand you on the side of a road like a failed piston motor. Because the 2 rotors work basically independently of each other you could blow a seal on 1 rotor and limp the car along on only 1 rotor to get home, get it somewhere to fix it, etc.
Old Aug 9, 2008 | 12:52 AM
so basically a compression test will let me know the status of my motor? thanks for the quick help, i really do appreciate it. and sorry for the noobness. basically that would be the first step in figuring out what is going on?? and yes it was very hot that day, 90+
Old Aug 9, 2008 | 12:54 AM
mac11's Avatar
Rotary , eh?
sounds like it is no big deal if the car has returned to normal since then.
But yes to check the health of a rotary, or any other motor, a compression (and leakdown for a piston) test is where to start.
If you go to a dealership they should have an instrument that will give you 3 numbers for each rotor, 6 in total, and they should be able to give you a printout of what these numbers are. If you get it done bring them back here and post them up. Don't just let a dealership assclown tell you something like you need a new motor w/o verification.
Old Aug 9, 2008 | 12:56 AM
thanks sir. i can get this from my local dealership right? $100 i believe i read on another thread.
Old Aug 9, 2008 | 12:57 AM
Easy_E1's Avatar
It could be your ignition coils. Could be a bad Catalytic Converter. Could be a bad fuel pump. Could be a clogged air filter. Could be bad gas. Could be a bad plug wire. Could be bad spark plugs.
Oh and 90 + is not hot. Our overnight low a couple of days ago was 97 degrees.
Old Aug 9, 2008 | 12:59 AM
Easy, what would you recommend? all feedback is welcome. should i change plugs and coils? would the compression test be able to tell me if those things would need to be replaced?
Old Aug 9, 2008 | 01:03 AM
Easy_E1's Avatar
How many miles on the car?
BHR can rebuild your engine, but is it necessary? I think I would just have a compression test done. But the thing that it runs fine is questionable to the compression issue. A little service history would be good. Anything replaced?
Where are you at str8hustlin?
Old Aug 9, 2008 | 01:11 AM
coils, fuel pump, cat in that order..
the compression test will answer the question.
btw, you now have a 8yr 100k mile warranty on the motor..
Old Aug 9, 2008 | 01:14 AM
mac11's Avatar
Rotary , eh?
no..
Old Aug 9, 2008 | 01:20 AM
compression test will tell if the motor is good or bad.
if you have flooded once or twice i would go with cat. covered under warranty..
if you have not changed the plugs in the last 20k miles i would do that first.
if you coils have not been changed that would be # two.
then the fuel pump.. it sounds a lot like that. do you premix?
mac. the new avatar cracks me up. thx.
Old Aug 9, 2008 | 01:21 AM
mac11's Avatar
Rotary , eh?
lol, thanks. been looking for this one for a long time.
Old Aug 9, 2008 | 01:26 AM
Easy_E1's Avatar
Swoope has a good scenario for you to follow and check
I have this on the windshield.
Old Aug 9, 2008 | 01:28 AM
car has around 78k miles.
never had anything replaced other than fluids and tires.
Old Aug 9, 2008 | 01:29 AM
i guess i am to old to find good stuff like that..
mac11's Avatar
Rotary , eh?
replace the plugs and coils (and again every 30,000 miles) your car (and motor) are fine.
Old Aug 9, 2008 | 01:31 AM
never flooded.
i have a rp supercat.
havent changed the plugs or coils since i had the car (about 40k miles)
Old Aug 9, 2008 | 01:32 AM
Easy_E1's Avatar
I concur. More than likely just and ignition issue.
Old Aug 9, 2008 | 01:33 AM
if its the coils and plugs would any of you recommend just upgrading to the mazsport ignition solution??
Old Aug 9, 2008 | 01:41 AM
mac11's Avatar
Rotary , eh?
If you have the money, absolutely. Mazsport puts out great products.
Old Aug 9, 2008 | 01:44 AM
Easy_E1's Avatar
Wait a couple of weeks for the BHR ignition system. It's half the price and much better. I have it on my car now and it works great.
BHR Ignition System
Old Aug 9, 2008 | 01:46 AM
mac11's Avatar
Rotary , eh?
Wait a couple of weeks for the BHR ignition system. It is half the price and much better. I have it on my car now and it works great.
have you had the mazsport system on your car?
