8 performing like shi......
Old Aug 6, 2008 | 12:11 PM
quazmosis's Avatar
Chode
not only the plugs but maybe the coils as well. Do you have a cat by chance? would that be plugged at all?
Old Aug 6, 2008 | 01:00 PM
Roaddemon's Avatar
Originally Posted by 12oclock
Did some searches and I'm hoping it's the plugs so I'm changing those alter today. Just wanted to get some personal opinions though. Only 2 differences in the last week I can think of that might have something to do with this 1) I quit premixing for a couple of days after my engine light came on, started premixing once it went off again and 2) did some serious revving and donuts on Friday.
But basically it just hesitates real bad when accelerating, it's pathetic. I might as well be driving my civic. Thanks for any insight......
Mine is running great. sorry can't help you. Take it to the dealer. Save yourself the aggrevation and worry of being your own mechanic. They have diognostic equipment you don't.
Old Aug 6, 2008 | 01:34 PM
*sigh*
stick with your Civic.
Im tired.
Old Aug 6, 2008 | 02:12 PM
quazmosis's Avatar
Chode
For what I've read, and please read so yourself but coils are a simple install. I can't speak from experience but what I've read pretty easy. Although I'm going to find out real quick since its on my to-do list. Definatly if that CEL comes back on again get it pulled, then bring the code back here and people will run over their own mother to tell you what it means.
Old Aug 6, 2008 | 02:23 PM
It's only easy if you are mechanically inclined and have the proper tools.
Old Aug 6, 2008 | 04:00 PM
Schimmle's Avatar
El Terrifico
actually I've never done anything like that on a car before. I just took twice as long as it said it would. I had simple tools. Wrenches, sockets. Its honestly not that hard. It seemed over whelmin when I first got started.
Old Aug 6, 2008 | 04:26 PM
gary935's Avatar
Love my RX-8
Hesitation
I can give you my personal experience that happened yesterday. I was driving to work when my 8 started to hesitate very bad. (2004 MT 55K) Every shift I threw resulted in the car hesitating and buckling like if I had never driven a stick before. I was lucky in which the Mazda Dealer is about 2.5 miles from my work. Of course it was the worse 2.5 miles driving as the car almost stalled 4 times.
I had to drive in 3 gear and stay around 40 mph. Anything higher would result in the CEL flashing and a far worse hesitation then before. Made it to the dealer and was told a couple of hours later that they needed to change the coils, spark plugs and ignition wires. I needed the car so I authorized the work to be done which came out to $ 696.04. I am sure that was way to much but I was expecting to be told the engine was going to need to be replaced. When I did get the car back at the end of the day it rode like brand new. I realized now that the car was having slight symptons before this but I did not catch on until it was to late. At least I made it to the dealer.
Old Aug 6, 2008 | 04:27 PM
quazmosis's Avatar
Chode
wow that's expensive
Old Aug 6, 2008 | 04:28 PM
tajabaho1's Avatar
Destroying Threads
I just changed my coils today because mine were crisp fried...............better to check your spark plugs first
Old Aug 6, 2008 | 04:40 PM
luis@championsmotorsports's Avatar
possible problem
replace your plugs for sure,,,maybe a fuel filter,,,also check your air filter,,,,and yes dealers are expensive most of the work is easy...and a DYS can do ...if you need help email me Luis@champions-motorsports.com
Old Aug 6, 2008 | 04:52 PM
flip's Avatar
LOVE / HATE Relationship
Hopefully its just as simple as the others have stated... that's all i'm gonna say. Good luck
Old Aug 6, 2008 | 05:08 PM
tajabaho1's Avatar
Destroying Threads
it is very simple, the sparkplugs however, you will need a jackstand and remove your wheel
Old Aug 6, 2008 | 05:15 PM
quazmosis's Avatar
Chode
Sparkplugs also fairly simple.
Old Aug 6, 2008 | 05:16 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah def sounds like coil's and plugs everything very easy as long as u sort of know what ur doin and have the basic tools...
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
archon
Oct 1, 2015 06:08 AM
drlubell
Sep 26, 2015 11:58 PM
