How to Hook up Subs to Base stereo
Old Nov 25, 2003 | 01:19 AM
SiCkRx-8's Avatar
Sorry guys but i looked through all th threads and did a search, but i have no idea how to hook up the old box i have to the base system. Anyone have a step by step procedure?
Old Nov 29, 2003 | 09:35 PM
mxmedina's Avatar
Cool Here is my set up
[IMG]Kenwood DB+ 10" Pus kenwod 800 Wat amp/1 capacitor[/IMG] :D
Old Nov 29, 2003 | 10:58 PM
rotarygod's Avatar
mxmedina: not to be a dick because it is obvious that you're proud of your setup but come on. Everyone has seen your setup already. Over and over again. Just go pick a thread and the pictures are there. It isn't even a custom install either. If you like it then that is all that counts but you don't need to show us everyday in 30 different threads. That wasn't his question anyways. It isn't has anyone installed subs. The question is how to hook up subs to the factory stereo.
SiCkRx-8: the answer is that you obviously need to run a power wire from the battery to the amp. Do not run the wire through the door channel from the fender. Take the time to figure out where to run the wire through the firewall inside the vehicle. You need a good ground wire so pick a good spot on the metal near the amp and ground it there. An existing bolt may be just fine. You will need a line level converter tapped into the signal wires to the factory amp. This is easy as there is a factory amp under the rear deck in the trunk. For the remote turn on wire find 12V switched somewhere. A wiring schematic may be very helpful. Mr. Wigggles on the forum has posted a wiring schematic somewhere on here so do a search under his name and start looking. It is actually straight forward.
crimson809
Aug 14, 2016 10:03 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Stubbs
Sep 27, 2015 04:06 PM
