There is a tire pressure monitor?
Old Nov 24, 2003 | 07:53 PM
starstar5's Avatar
Question There is a tire pressure monitor?
I read some of the post and 1 thing comes to my mind that is, there is a tire pressor sensor or monitor? I can't find it anywhere on the dashboard.
What is the psi setting for performance and for fuel economy that you guys would recommend? And how does the stock tire fare in snow or rain condition?
Old Nov 24, 2003 | 07:55 PM
mikeb's Avatar
100% Italian
32 psi is recommended
Old Nov 24, 2003 | 08:11 PM
Gord96BRG's Avatar
Re: There is a tire pressure monitor?
Stock tires are great in the rain. DANGEROUS and entirely useless in the snow. However, with winter tires, the RX-8 goes great on snow (I've had my winter tires on for 4 weeks now, and we've had snow for over 3 weeks). If you have the stock tires and it snows - leave the RX-8 parked until the snow/ice is gone. Seriously, you'll only bend it if you try to drive in snow on the stock tires.
Regards,
Gordon
Old Nov 24, 2003 | 09:04 PM
starstar5's Avatar
Thanks guys! Now, anyone know anything about that tire pressure monitor? Is there one, yes or no? I just want some definite answers.
Old Nov 24, 2003 | 09:21 PM
jtimbck2's Avatar
Yes, the RX-8 has a tire pressure monitoring system. It's an idiot light, it lights up when any of the tires is outside (above or below) the prescribed pressure range. It doesn't tell you which one, that's so you check the pressure in all of them when necessary.
Old Nov 24, 2003 | 09:32 PM
matt's Avatar
it's outlined in your owners Manual and listed on the window sticker.......
Old Nov 25, 2003 | 02:19 AM
Haze's Avatar
It's right on the dash as a yellow flattened tire symbol idiot light. You can see it in the pre-start diagnostic light up.
Old Nov 25, 2003 | 05:13 PM
RXATE's Avatar
I'm told that the Canadian version of the car does not have the pressure monitor. Confirmed this when putting on new rims and snow tires yesterday. Possibley some American and other international versions do not also.
Old Nov 25, 2003 | 06:46 PM
jtimbck2's Avatar
The TPMS is a Standard feature on all US-spec RX-8's. I don't know about other countries.
Old Nov 28, 2003 | 11:50 AM
starstar5's Avatar
So it's just a light. I was expecting a little more, like a display of psi. Regardless, I am not sure if it's working, maybe I should flat 1 of the tire out? Anyway, yesterday I pumped the tires to 35psi (the measurement is from the air pump, not sure how accurate that can be) and nothing is said or noted. Possibly my tire pressure monitor is not working, or not there? After all, my car is one of the first batch.
Old Nov 28, 2003 | 11:54 AM
Omicron's Avatar
The US spec car has had it from the start, so you've probably got it. Does the idiot light (left gauge pod, yellow, 3/4 "tire" icon, toward the center) come on when you start the car, then go off? If so, the system has passed it's "pre flight" inspection. If it comes on and stays on, there is a problem either with the system or with a tire being low.
Old Nov 28, 2003 | 12:47 PM
eccles's Avatar
Prodigal Wankler
To clarify further, the TPMS light is a yellow tire cross-section with an exclamation point.
Old Nov 28, 2003 | 01:59 PM
Omicron's Avatar
Yah, that's what I meant... :D
Old Nov 29, 2003 | 02:07 AM
Sin's Avatar
Sin
Yes
Old Nov 29, 2003 | 01:53 PM
35 psi is not enough over to trip the light. i believe the over limit is 43 psi
crimson809
Aug 14, 2016 10:03 PM
OnebaddRx8
Oct 17, 2015 10:05 PM
drlubell
Sep 26, 2015 11:58 PM
