BHR Throttle Body Spacer install
I originally had these posted in the BHR Products thread.
However I felt that it didn't really belong there.
Anyways this isn't a DIY but we could talk about any problems/advice people have to offer.
I did order the BHR Stealth nozzle as well however I ran into a couple of small issues with it.
1) The jets that I intended to use from my Zex kit didn't fit, which was the primary reason I didn't install it and
2) The fitment of the hoses to the nozzle was going to be very tricky as they needed to run to the opposite side of the TB Spacer as the Zex nozzle shown in the pics below. There is also a plastic clip on that side that hold the TB wiring harness that will make it tricky. It's not impossible but I just didn't feel like wasting my time when I knew I didn't have the jets for the stealth nozzle anyways.
The whole thing is simple to remove and when I get my jets for the stealth nozzle I'll remove the Zex nozzle. It will only be a about a 2 beer job maybe 3 if I spend extra time routing the hoses.
Ain't it cool looking.... damn I'm wet
BHR Stealth vs ZEX
Taj's setup.. sorry dude had to do something
Everything removed
I need BHR coil upgrad
Installed 1
Installed 2
Installed 3
Installed 4
BHR Stealth vs ZEX
Everything removed
Installed 1
Installed 2
Installed 3
Installed 4
really need to get this... can finally clean up my install. installed my kit in january but wasnt the cleanest looking but didnt care since this was coming out... thought it would be out earlier but never cleaned it up since it was coming soon lol. looks good.
1 Alcohol nozzle hole, located in the middle on the side.
1 Zex, Dynotune etc nozzle hole located below the alcohol nozzle hole on the side
1 BHR Stealth nozzle hole located in the middle at the bottom
The BHR Stealth nozzle fits Dynotune jets, however Ray has suggested that I try swapping out jet holders from the Zex to the Stealth nozzle and see how that works.
I'll be doing that today, will report back later.
UHATEIT
Mar 31, 2019 05:31 PM
9krpmrx8
Nov 5, 2015 11:45 PM
harithac
Aug 26, 2015 09:24 AM
