changing my oil early morning..
Old Jul 12, 2008 | 02:47 AM
Z0oMzo0m's Avatar
so im due for change, instead of the 5w20 castrol i have been using, i want to get a heavier oil. i live in FLORIDA. should i go with a 10w20? what would be better for the seals?
Old Jul 12, 2008 | 03:11 AM
StealthTL's Avatar
I don't think you will find any 10w20.....
You would want a higher second number, this would give more protective viscosity at operating temperatures.
The first number is its 'cold' viscosity, and a 5 is probably better for quick flow to the bearings, but 10 is fine too, so a good 5w30 or even a 10w40.......
S
Old Jul 12, 2008 | 06:57 AM
Florida ? use 10w40.
Old Jul 12, 2008 | 06:17 PM
04RX8man's Avatar
Rotary Powered Countryboy
I live in the 407 (orlando) and just moved to 5w30 3 days ago (from 5w20 gtx) and it seems to run alittle smoother and sound alot nicer at high rev's (prob just me thinking that) but i would go for 5w30 or 10w30 i'm just not sure aobut anyting more than 30
Old Jul 12, 2008 | 09:15 PM
Nubo's Avatar
Lubricious
I'ved used Mobil1 5W30 for most of my changes (34,000 miles). Recently I've started using 0W40 for topping-off. I figure it will counteract any viscosity shear-down or fuel dilution in-between changes. I usually average adding about 2 quarts or so in between changes. I also started using Marvel Mystery Oil for pre-mix several months ago, at a rate of about 250:1.
Old Jul 12, 2008 | 09:42 PM
MMO is not good. It doesn't burn clean enough for the seals. It will leave a residue and build up carbon.
Old Jul 12, 2008 | 09:45 PM
mysql's Avatar
Doppelgänger
0-10 w 30-50
I'm on 5-30 for the first few thousand miles on my engine, then going to 40 or 50 weight. whatever I can get my hands on.
Old Jul 13, 2008 | 12:19 AM
lots of info here does not agree with that statement..
i am not using it, but i might give it a whirl when what i use runs out.
and to the op. i ran 5 / 30 for a long time. have just gone to 10 / 40. am in orlando.
Old Jul 15, 2008 | 10:43 PM
DOMINION's Avatar
I don't buy Kool-Aid
Use 5-W30 Oil
Skyl3r
Dec 2, 2019 04:51 PM
Pelleilee
Sep 29, 2019 10:07 AM
uZu
Dec 30, 2015 12:35 PM
motohegg
Aug 23, 2015 08:14 AM
Modern2Strokez
Aug 16, 2015 01:07 AM
