JIC's are here!
Old Nov 21, 2003 | 04:29 PM
syntrix's Avatar
I like cheese!
JIC's are here!
Here's a teaser pic:
Just started on the car, should be done tonight
Old Nov 21, 2003 | 07:34 PM
Speed Racer's Avatar
Certified track junky!!!
Syntrix,
Are you documenting your install? I'd be interested in finding out how hard it was to install and adjust them to your driving style.
Old Nov 21, 2003 | 08:06 PM
mikeb's Avatar
100% Italian
sweet
I saw mazdatrix's car today and it has that setup
It was slammed real low
Old Nov 21, 2003 | 08:12 PM
syntrix's Avatar
I like cheese!
Originally posted by Speed Racer
Syntrix,
Yes, I've been taking pics through out the whole install, and plan on doing a complete write up!
So far so good, but there's a few tips you might want to have if you do suspension yourself to make it easier.
I even got pics of the rear inside the trunk, and with the rear trailing arms disconnected.
I have it 3/4 of the way done, but.......
Sway bar links... just like early WRX, they are plastic innerds with 4 press melt tabs at teh end of the "ball joint".
I just jb welded it back into place and hopefully it will hold just fine... heh compared to plastic!
I even had to wait for a tow truck for an hour and take about 45 mins to help the guy get it on the track and strapped down properly, LOL. This for my 03 R6, not the car.
Stay tuned for lots of pics and a detailed writeups!
Sorry, these pics are big, I still have to crop them down, but you will see images like this:
Old Nov 22, 2003 | 12:54 PM
syntrix's Avatar
I like cheese!
Here's a preview of the writeup:
http://rx8.swankmonkey.com/suspensio...ers/index.html
Please give me some feedback, and remember that I wrote it very late last night on the virge of passing out.
I just work up and I'm going to get the heights adjusted right now, and should be able to get in for corner balancing next weekend
Old Nov 22, 2003 | 03:31 PM
VividRacing.com's Avatar
Glad to here it Syntrix. We installed ours this week. Give you a little hint on the rear to make the install go easier. Unbolt the endlinks on both sides of the sway bar and roll it out of the way. Then remove the mounting bolt for the main latteral link and move it out of the way. Now you have more room to drop the factory set up and it's way easier onthe fingers, trust me!
Old Nov 22, 2003 | 04:47 PM
Mazdatrix's Avatar
Former Sponsor
Yes, rear link needs to be dropped -- applies for any rear shock or spring install.
It's what we mentioned in the 11/15 post: https://www.rx8club.com/showthread.p...&highlight=jic
about our JIC's we installed weeks ago.
Old Nov 22, 2003 | 07:30 PM
syntrix's Avatar
I like cheese!
Yeah, dropping them is not a problem, just mark them so they are close, cause you are going to have to get an alignment anyway!
I agree that these are just a tiny bit harsher than stock going in a straight line, they really plant the car when getting at the limits in corners!
Hey Dan/Huff/Vivid or anyone else, was you JIC Box marked 9 and 5 for the springs?
Mine was.
Old Nov 22, 2003 | 07:42 PM
syntrix's Avatar
I like cheese!
Here's one pic of the car, need to get some more side shots:
There's a few more here, from our Vegas meet today:
http://www.swankmonkey.com/mig/index...gas_Mazda_Meet
Old Nov 22, 2003 | 08:49 PM
mikeb's Avatar
100% Italian
very nice syntrix
my back seems to be lower than my front
too bad I cant adjust mine like yours
Old Nov 22, 2003 | 08:55 PM
syntrix's Avatar
I like cheese!
Mike,
Let the springs settle for a bit. I have looked at the pics in your post, and I think it might be an optical illusion if you are just looking at the fender and the gap to the wheel. Rears have less gap stock. Also you have the side skirt kit on that might be making it appear to look like the back is lower.
Either way, give it some time to settle, then park on a level surface, and walk way aways from your car and look at the bottom of it. Hopefully it's near even
I have my setup with the front just a tiny bit lower than the rears.
Old Nov 22, 2003 | 09:43 PM
syntrix's Avatar
I like cheese!
Also, for anyone that has done coilovers.....
Have you noticed that the shafts of the stock struts feel extra oily? Like a weak seal going into the strut body, but not leaking anywhere?
I was just really stunned at how oily the surface of the shafts were.
Old Nov 22, 2003 | 10:20 PM
Syntrix-
The shafts didn't seem over oiled on my set. The adjustment **** on the rear driver's side unit was frozen in place so I had to break it loose with a wench. I'm thinking of cutting out a small hole in the sheetmetal so I can stick my fingers in there to make ajustmentsl.
Old Nov 22, 2003 | 10:24 PM
syntrix's Avatar
I like cheese!
No, I meant the stock struts!!!
I'm also thinking of drilling a hole in the rear metal, and using some rubber tubing to get over the adjustment ****!
Hey, how was your box marked? Do you still have it? They are supposed to be 8/5, but my box was marked 9/5 and there's no marking on the springs to tell what they actually are!!!!!
I'm VERY pleased with them, and JIC has once again lived up to it's name!
EDIT: either way, we are a select few that are enjoying these coilovers before the public can actually get their hands on them. Good stuff so far, and shipments from japan to JIC should be 1st week in Dec!
Old Nov 22, 2003 | 10:41 PM
syntrix's Avatar
I like cheese!
And here's a nite pic... I'll get better ones tomorrow:
Old Nov 23, 2003 | 11:43 AM
oosik's Avatar
Women are finally good for something else, eh? :D
j/k
Old Nov 23, 2003 | 11:45 AM
syntrix's Avatar
I like cheese!
j/k
Bahahahaha! That's good!
Old Nov 23, 2003 | 02:01 PM
syntrix's Avatar
I like cheese!
Excellent pictures! I'll surely buy everything
Also can't wait for the rear adjusters, since you have to drop the rear setup to make any adjustments.
Any insight as to how these are going to work?
Old Nov 25, 2003 | 11:28 PM
BOOSTD 7's Avatar
RX8Club.com Founder
I see nothing wrong with this thread, moving back to a visible forum.
Old Nov 28, 2003 | 07:26 PM
syntrix's Avatar
I like cheese!
And for those subscribed via email for this.....
How to add rear adjusters so you can adjust dampning without drilling:
https://www.rx8club.com/showthread.p...threadid=15522
Booyah!!!
darkducati
Apr 8, 2004 09:32 AM
