Strength of passenger wiper nozzle spray stream?
Old Jul 10, 2008 | 04:19 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
How far does the of passenger wiper spray nozzle stream go? I think the third jet, farthest to the right/outside of the car hits the bottom of the windshield and the middle one is not that great either.
It is bothersome since it doesn't spray with enough fluid to completely clean that area and so it leaves crud streaks.
I'm taking my car in for a few things next Wed. and want to get feedback in case they feed me something like "its within specs" etc.
Old Jul 10, 2008 | 04:23 PM
Socket7's Avatar
ಠ_ಠ
My sprayers are all pretty strong, but some of them arent aimed very well. you can take a needle and poke it into the sprayer to adjust the aim.
My old honda accord's sprayers worked on and off depending on if the hose got kinked the last time i closed my hood.
Old Jul 10, 2008 | 04:24 PM
ken-x8's Avatar
All the streams on mine hit the windshield about halfway up. and look pretty strong. Nicely spaced.
There are eight streams total - very appropriate.
Ken
Old Jul 10, 2008 | 04:27 PM
MazdaManiac's Avatar
A weak stream is usually a sign of prostate issues.
Old Jul 10, 2008 | 04:55 PM
WooHoo's Avatar
OK, OK, It's hers!
Damn MM, you stole my line!
Old Jul 10, 2008 | 04:58 PM
I was wondering when the jokes would start flying. I guess I can try using the end of a plastic coated metal paper clip and see what happens.
Old Jul 10, 2008 | 05:05 PM
ken-x8's Avatar
Originally Posted by CarAndDriver
...I can try using the end of a plastic coated metal paper clip ...
Ouch!! Depending on which stream you're talking about.
For the windshield sprayer, that could be a little thick. You might need to look for a thinner wire - take a look at the size of the hole. Socket7 speaks wisely - that's how you aim those nozzles. Also how you clear them if they get clogged.
Ken
Old Jul 10, 2008 | 05:11 PM
Use a pin. Nothing bigger.
dozer's Avatar
on his 3rd rx8
Lol!!!!!^^^^
Old Jul 10, 2008 | 05:53 PM
04RX8man's Avatar
Rotary Powered Countryboy
Yeah a pin will work both my sprayers are pointed about halfway up the windshield and evenly spaced sometime i have to clean them after a wax job because of the damn wax getting in there but a sewing needle or something like that works
Old Jul 11, 2008 | 03:51 AM
air in opposite direction, with the hoses disconnected..
and the weak stream issue. i think they have a pill you take and go fishing, problem solved.. maybe you have to ride a bike or kayak.
vapor2
May 4, 2020 03:53 AM
nferguson88
Oct 6, 2015 12:45 PM
SimonT182
Oct 2, 2015 10:33 AM
archon
Oct 1, 2015 06:08 AM
XianUnix
Sep 29, 2015 03:48 PM
