Factory Tinted Window Question
Old Nov 20, 2003 | 09:30 AM
FighterPilot's Avatar
Question Factory Tinted Window Question
My tinting on the rear window has a sort of patterned look to it...only when viewed from an angle, but you can see small circles repeated in straight lines horizontally on the window.
Anyone have any idea what I'm talking about? Suggestions?
Old Nov 20, 2003 | 09:51 AM
jdaled's Avatar
I know what you're talking about, I've seen it on other cars before, but only when I was wearing polarized sunglasses. It has to do with the UV protection, I think.
Old Nov 20, 2003 | 12:35 PM
mikeb's Avatar
100% Italian
I know what you are saying but my factory tint doesn't have that
Old Nov 21, 2003 | 02:19 AM
Nubo's Avatar
Lubricious
Re: Factory Tinted Window Question
Yeah, this always seems most visible on new cars. I'm not sure what causes it, but I don't think it's the tinting - I see it on non-tinted windows as well. Hmmm. time for a google search....
Update - here's one explanation - the tempering process
http://bimmer.roadfly.org/3series/me...w05/16379.html
Old Nov 26, 2003 | 12:38 AM
S3/P3/E2's Avatar
8 w/ Trunk Monkey option
It's called "spot-polarization" (seriously). If the glass were completely polarized, you'd receive light in through it that arrived only at a specific angle. What the spot polarization does is attempts to limit the amount of light that comes in through the window from all manner of random angles to cut down on glare. Think of it this way - if the entire back window was polarized glass and you were wearing polarized sunglasses as well, you'd see little or nothing through it because the two would be mutually exclusive polarized filters. The back seats of the Navy's S-3 Viking jet have windows that work on this principle (rotate the inner polarized "filter" to essentially go from clear to blacked out windows to allow monitoring tactical displays in bright daylight).
Make sense?
Old Nov 26, 2003 | 05:24 PM
Dissolved's Avatar
Senior Member :D
funny. I always see this with polarized glasses as well. LOL thanks for clarifying
Old Nov 26, 2003 | 05:40 PM
S3/P3/E2's Avatar
And you will... They won't "go black" (sorry if my post sounded as if they would). The amount of polarization is just enough to cut down on glare. Whew - there'd be a lot of people on the road w/ some serious issues if polarized sunglasses were all it took to black out your windows! :D
Old Dec 18, 2003 | 03:31 PM
Golfer's Avatar
I read somewhere that those "Spots" you see (especially with polarized glasses) is a result of the manufacturing process for saftey glass to ensure the glass breaks in small pieces. I recall that it was from cooling the glass using water jets. Not sure if its true but it makes sense.
Old Dec 18, 2003 | 04:05 PM
Genom's Avatar
Not so Super right now
If ya ever go to an amusement park where they have the 3D movies, take the glasses you get off your face. Now rotate them 90 degrees and look at the other people. Notice all the black looking lenses? Thats how things look through very specific polarization filters. Your vieweing a more subdued version of that.
Old Dec 19, 2003 | 01:17 AM
S3/P3/E2's Avatar
Yep - excellent example Genom.
Old Dec 19, 2003 | 03:57 AM
Nubo's Avatar
Lubricious
Yes, from tempering safety-glass:
What you are seeing is varying light polarization caused by the glass tempering process. The rear window glass is tempered both to toughen it and to prevent shards when the glass does shatter.
Tempering is accomplished by prestressing the glass surface with differential cooling. This is done with air jets -- think of an air hockey table. The spacing of the jets determines the checkerboard pattern. The difference in the glass density and index of refraction is very tiny, but your eye is tuned to detect subtle patterns.
It's not a problem, it won't get worse or better, and it cannot be polished away. Think of it as confirmation that your glass was properly tempered.
source - http://bimmer.roadfly.org/3series/me...w05/16379.html
Old Dec 19, 2003 | 04:19 AM
Nubo's Avatar
Lubricious
Another reference:
When viewed under particular lighting conditions, especially when viewed at a grazing angle, faint
shadowy spots caused by the air quench process can often be seen in heat treated glass. These spots
can be seen in transmission and in reflection, and at most viewing angles, other than directly facing
the glass. They become very visible when polarizing sun glasses are worn. They are easily seen on
a sunny day when the light comes from the blue sky or is reflected from clouds. They probably
would not be visible on a grey, cloudy day. These spots are a normal function of properly tempered
glass and are mentioned in section 7.5 of ASTM C 1048 standard for heat treated glass. They are
more visible when both lights of glass in an insulating glass (IG) unit are tempered. They are often
seen in the sloping tempered back windows of cars, and in Asia they are very obvious in some small
truck tempered front windshields.
The attached illustrations show a simplified explanation of the physics involved in their formation:
Illustration #1 shows how light coming from the sun is made up of oscillating waves in planes at
different angles to each other. When sunlight interacts with molecules of air and very small dust
particles in the sky it becomes polarized. The polarized waves vibrate mostly in one direction.
Illustration #2 shows how the quench jets in a tempering furnace cannot cool the glass completely
uniformly. As a result some areas are cooled faster than others resulting in differential shrinkage
which creates areas of different compressive stress. When glass is stressed in the quenching
operation, with its corresponding very slight change in density, it becomes birefringant or
polarizing, that is it partially blocks or passes polarized light. The greater the stress the greater will
be the polarizing effect.
Illustration #3 shows schematically how vertically polarized light can easily pass through the
vertically polarized sections of the glass to give bright spots but it is diminished when passing
through other areas polarized at a different angle to give relatively darker spots.
The spots are not an indication of absolute tempering level; they simply show areas of relatively
more, or less, tempering stress. Given the nature of the quenching process it is physically
impossible to quench a plate with absolute uniformity. The degree of tempering and the uniformity
of tempering throughout the plate can be tested by other methods such as surface stress instruments
or by examining the break pattern after fracture.
Source: http://www.pilkington.com/resources/ats157.pdf
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
yankeepicker
Sep 11, 2015 05:42 PM
TJSiegrist
Sep 10, 2015 09:29 AM
Rupanrx
Sep 4, 2015 06:44 AM
