Sparkplug question
Old Jun 18, 2008 | 03:15 AM
Grifter11's Avatar
RX-8 or Supra Turbo
Sparkplug question
Does the new Renesis rotary engine eat spark-plugs like the rotary from the RX-3 my dad had when he was younger ?
Old Jun 18, 2008 | 09:12 AM
Greenblurr93's Avatar
Sotally Tober
define 'eat spark plugs'.... like the game 'hungry hungry rotors?'
Old Jun 18, 2008 | 09:22 AM
mysql's Avatar
Doppelgänger
generally speaking, changing it every 30k - 60k is about normal.
I was changing mine out once a year, but I used the rx7 spark plugs and they only cost $6.50 each.
Old Jun 18, 2008 | 09:37 AM
Sotally Tober
could you please elaborate on the 'rx7' spark plugs? is there a specific year to get? turbo or non turbo? any difference in these over the rx8 plug? if they are the same and provide the same result as the rx8 plug, im going to stop buying $20 plugs...
Old Jun 18, 2008 | 10:29 AM
SilverStreak's Avatar
The RX8 plugs are Iridium plugs ($20 each) and are supposed to be changed out about every 30K miles by the manual. Some folks here have switched to the "standard" type of plugs rather than the Iridiums (like Platinum tips, etc.) at ($6-$7 each). The tradeoff seems to be needing to change the plugs more often (every 10-15 K miles). Search on plugs and you should find what people have been using.
Old Jun 18, 2008 | 11:29 AM
hakuna matata!
does the renesis "eat oil"?
Old Jun 18, 2008 | 03:26 PM
whenson417's Avatar
I just bought a spark plug cleaner from Northern Tool and Equipment for about $25.00. I am able to clean all the crud build up on the plugs to make them last a hell of a lot longer than normal. I do not think I will have to purchase new plugs for a long time since I have kept all the old ones. I now have about 12 spark plugs I can swap in and out as needed.
Old Jun 19, 2008 | 07:24 AM
Sotally Tober
watch out for the cleaners... as our plugs are both platnum and iridium coated.. if the coating comes off, then plug wont function corectly
Old Jun 19, 2008 | 10:28 AM
ken-x8's Avatar
No. It eats gasoline. It sips oil, kind of as a seasoning.
Ken
Evan Gray
Nov 24, 2015 01:00 AM
nferguson88
Oct 6, 2015 12:45 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
pjwermuth
Sep 28, 2015 11:36 PM
kody59
Sep 28, 2015 03:43 PM
