Zoom Power Cleaner question
Old Jun 17, 2008 | 10:28 AM
Gdawg522's Avatar
Rotary Addict
OK so My 8 has 75,000 and I have a feeling that this was never done to it. My 8 is down right now cause I'm changing the ignition coils, plugs, and wires because I was having some power loss problems. I'm still waiting for my wires to get here from mazdatrix which wont be til wed or thurs. Do you guys think I could do this cleaning and then let it sit until I can get everything put back together or should I just wait and do it once I get the ignition system back up and running. I didn't know if the cleaner would dry up or cause damage to the engine by sitting in it for a day or so. Thanks for your help!
Old Jun 17, 2008 | 12:23 PM
Just wait until ur wires come.
2 days without a car shouldnt be able to kill you
Old Jun 17, 2008 | 12:26 PM
Gdawg522's Avatar
Rotary Addict
Yea I just didn't know if there is any benefit to letting the cleaner soak in the housing. I'll just wait til thursday to do the cleaning. Oh another question. Should I put all the ignition stuff in the car adn put the intake system back together and make sure everything is running ok before I take the intake back out to undo the eccentric shaft connector and do the cleaning. That way I know the car is running properly before I spray all that cleaner into the housing? Hopefully this will restore my power loss problems. My 8 getting zoom cleaned, new coils, wires, and plugs. She should run like new. Hopefully
Old Jun 17, 2008 | 03:32 PM
bryanl's Avatar
i would suggest putting everything back together to make sure your ignition system is running properly, besides, you have to have the engine warmed up for the cleaning procedure. you shouldnt have to rip out your intake again, as the eccentric shaft sensor is down towards the bottom so just jack the car up and get in there.
Old Jun 17, 2008 | 06:48 PM
Actually you have to wait for ur wires to come.
cuz you have to warm ur engine up b4 u can spary the engine cleaner. so
I should add this to my DIY. let me check.
Old Jun 18, 2008 | 07:16 PM
Gdawg522's Avatar
Rotary Addict
ok so how exactly do I get to this sensor from the bottom of the car. What panels come off to get to it because I can't see if from the bottom of the car right now.
Billy Marcial
Mar 1, 2018 06:50 AM
uZu
Dec 30, 2015 12:35 PM
tgaffner
Aug 20, 2015 10:55 AM
groll69
MW RX-8 Forum
Aug 17, 2015 04:21 PM
