Going from +50 offset to +48
Old Nov 17, 2003 | 09:45 PM
slavearm's Avatar
Boost Junkie
Will there be any noticable difference in handling. 2mm doesn't seem like much to me, but after trying out 18x8.5 with +40 I don't want to take any chances, as those tires made my car handle like ****.
Thanks for the imput.
Slavearm
Old Nov 18, 2003 | 01:55 AM
Landon_Starr's Avatar
Still lovin' it...
I went to a 45+ MM offset, and I haven't noticed any handling differences at all, but you were probably looking for a more scientific response.
Old Nov 19, 2003 | 06:39 PM
No Pistons's Avatar
I have a chance to buy a set of volk wheels from my brother off of his S2000. The +49 offset, 18x7.5 in front and 18x8 in the rear. The front have 225 and rear 245.
Just want to know if these wheels will fit the RX8 as I would love to take them off my brothers hands if they will.
-Drew
Old Nov 20, 2003 | 02:45 PM
Still lovin' it...
My 255 35 r20's fit ok. a 245 18" 49+ offset will fit just fine, as long as you have the 5x4.5(114.3) lug pattern and around the 45 series sidewall. 245 45 r18 is the size of the stock tires.
Fitment and functionality are there, as to the disparate impact of tire size changes have on performance, there has been much controversy involved with it, and I would suggest a search on the existing strings.
Another thing to keep in mind is the TPMS system, if you're going to integrate it, or kill the dash light, etc. etc.
Hopefully this helps you.
--L
Old Nov 20, 2003 | 03:21 PM
connor@tirerack's Avatar
Forum Vendor
The amount of sway you have with the offset is dependant on the style of wheel you are using. sometimes 2mm won't make a difference other times it will collide with your rotors. it really depends ong the shape of the spokes on the individual wheel. also keep in mind, the lower you make the offset the wide you make the tire track. when you increase the distance between the wheels you normally change the handling for the worse.
The S2000 and the RX8 have similar wheel specifications but the RX8 has larger brakes that require more clearance in both width and height. the information i have shows they will not fit correctly. the center bore is the same, the bolt circle is the same, offset and brake clearance are about 5-8 mm different.
Old Nov 20, 2003 | 05:19 PM
Still lovin' it...
I'm assuming the information you have also states my 20 x8.5 w/ 255 35 r 20's won't fit, too.
I would strongly suggest test fitting them if it's an option, sometimes with newer vehicles data isn't always the greatest (small statistical samples, limited actual fitments, etc.).
Connor's comment is very helpful, though, there may be aspects that may hurt your handling, keep in mind your personal preferences (if you're willing to make minor performance sacrifices such as a wider stance for looks, etc.) when deciding on the purchase, and make sure you look at all the possible information available.
--L
Old Nov 21, 2003 | 12:30 AM
No Pistons's Avatar
Thanks for all the help guys. When my brother is ready to sell them I will test fit them first and see how it goes.
Just for referance the wheels are volk GTN.
-Drew
Old Nov 22, 2003 | 10:40 AM
rx8cited's Avatar
What's the offset of the stock 18" RX-8 wheels or where could I find this number myself?
The following description of offset may be helpful to those who like me are not familiar with wheel offset:
http://www.tirerack.com/wheels/tech/offset.htm
Thanks,
rx8cited
Old Dec 3, 2003 | 12:11 AM
slavearm's Avatar
Boost Junkie
Stock Offset is +50 :D
Old Dec 3, 2003 | 05:47 AM
rx8cited's Avatar
slavearm,
Thanks. Got that and more answered at https://www.rx8club.com/showthread.p...threadid=15342
regards,
rx8cited
Old Dec 5, 2003 | 11:29 AM
Jhouse's Avatar
i run a 48 right now and unless you are the greatest technical driving expert in the world i doubt you would notice a thing. its 2mm sort of hard to notice anything on 2mm.
hufflepuff
May 30, 2016 10:45 AM
Richard Paul
Aug 17, 2015 01:49 PM
R2D2X8
Aug 17, 2015 08:47 AM
