taillights (yes i searched, still have q)
Old May 31, 2008 | 03:25 PM
Blackout04RX's Avatar
Need for Speed Satisfied
Ok I searched on ways to fix this, tried baking the light and then prying it, didnt work so well. I bought one off ebay and added more sealant around the whole thing. still fogging. now my thought is to take it to the dealer, wondering if anyone knows how long a warranty would be in effect with something like that?
Old May 31, 2008 | 07:13 PM
chrism's Avatar
Misfit Moderator TnC
4/50 original warantee should cover it otherwise your SOL
Old Jun 1, 2008 | 07:35 AM
RK's Avatar
RK
It's Not Easy Being Green
Your dealer will cover it if you're under warranty. If not you can figure out where the water is pooling and drill a hole to release it.
In terms of searching...
https://www.rx8club.com/showthread.p...ter+tail+light
https://www.rx8club.com/showthread.p...ght=rear+light
https://www.rx8club.com/showthread.p...78#post2287478
You might want to try some different spellings...
Old Jun 1, 2008 | 09:50 AM
WVBoosted8's Avatar
I drilled 3 holes in the bottom of mine and it worked perfect. No fog or water accumulation.
Old Jun 1, 2008 | 11:58 AM
VampireSix's Avatar
There is a new gasket design out that will properly seal the tail lights. Did it myself as I was out of warranty... gasket was something like $45 for a piece of foam from Mazda, but haven't had any issues since then (about a year ago).
Old Jun 1, 2008 | 01:34 PM
I have an 04, so I dont know that I am still under warranty. Where would I drill the three holes?
Old Jun 1, 2008 | 02:36 PM
VampireSix's Avatar
If you are under 50k miles, you should still be covered. If you arn't, buy the gasket and do it the correct way. Easy to do, just takes a few hours to let the inside of the housing dry out.
Evan Gray
Nov 24, 2015 01:00 AM
garryg
Australia/New Zealand Forum
Oct 1, 2015 04:54 PM
Evan Gray
Sep 26, 2015 12:30 PM
p8ntman442
Sep 23, 2015 09:18 PM
