HEY GUYS! 1st post, stupid question.
Old May 20, 2008 | 12:27 PM
monadzback's Avatar
So I just bought my 04' MT with 17k on it. I am coming from a 93 MR2 turbo, and I love this RX8. I don't know any one in my area who has one, so I can't look in their car to compare. My question is, where should my oil pressure be? Its about two ticks above middle. I checked the dip stick, and it looks a little over full from the dealership. What are every ones oil pressure readings? Thanks in advance. Also the search only yeilds two responces, both un-answered so don't flame me.
Jeb
VA beach
Old May 20, 2008 | 12:55 PM
bse50's Avatar
#50
it is a pressostat so it just stays there to tell you there's pressure, it doesn't tell you how the circuit is working or how much oil you have.
Hope that the term "pressostat" is the right one, so says my vocabulary but you never know!
Old May 20, 2008 | 12:59 PM
~0zzygirl~'s Avatar
Registered Mommy
That's where the pressure is, all the time. I don't think it ever moves, it's a dummy gage. Don't worry about it unless you want to know your real pressure, then go for an aftermarket set of guages.
If the oil is just slightly overfilled, don't worry about it, it should go down some in a few hundred miles. Dealerships tend to do that b/c this car burns oil and most people won't check in between services. Keep a close eye on it until you figure out how much your car uses and keep it topped up. Mine usually burns 1/2 qt every 1500 miles. If it doesn't use oil, you're either not driving it hard enough or your OMP isn't working properly.
Old May 20, 2008 | 09:31 PM
monadzback's Avatar
Thats what I was hoping for. Thanx guys. BTW any on in the VA beach area?
Jeb
Old May 20, 2008 | 09:53 PM
I8U's Avatar
I8U
Check in the NE sub forum...
1.21 gigawatts!!!
Feb 14, 2019 03:23 AM
Mazdakevin
Mar 10, 2016 12:32 PM
amshaw
RX-8 Multimedia/Photo Gallery
10
Aug 26, 2015 08:50 PM
MolecularConcept
Aug 5, 2015 04:43 PM
CA441914
Aug 5, 2015 11:33 AM
