Swap OE Spoiler with MS
Old May 19, 2008 | 11:43 AM
pyro0849's Avatar
Cool Swap OE Spoiler with MS
I would like to swap my current spoiler with the mazdaspeed version, but i'm not sure if its possible?
I don't remember, but I believe the guy who installed my current spoiler told me it was drilled into the trunk and then glued down. Does that mean I would have extra holes just sitting out in the open if I try to put on the MS version? Or do they use the same holes and I could just place the new one over the old installation site. If anyone has done this, or knows anything about it, it would be helpfull. Thank you!
Old May 19, 2008 | 11:50 AM
Mugatu's Avatar
Even My Dog Searches
i guess you dont know how to search? i only ask because you are about the 1000th person to ask this question.
Old May 19, 2008 | 12:16 PM
VampireSix's Avatar
I've been thinking about doing the same thing myself...
From what others have posted on this site, the Mazdaspeed wing uses two of the three holes (per side) that the OEM wing uses. The third, unused, hole is covered up by the lower part of the MS wing. I haven't heard of the OEM wing being glued down, but some people have reported having some minor scuff marks where the MS wing doesn't cover where the OEM wing sat on the trunk. Further, the OEM hole placement isn't always perfect for the MS wing, causing a small gap at the back part of the trunk.
Hope this helps!
Old May 19, 2008 | 12:56 PM
hakuna matata!
yes it is possible as the mazdaspeed uses the same holes as the oem spoiler.. however, depending on how long you had the oem spoiler on you will see some scuff or imprint marks on your trunk since the mazdaspeed spoiler doesn't cover entire area the oem did.
Old May 19, 2008 | 06:53 PM
pyro0849's Avatar
Thank you to everyone but Mugatu... seems some people like to post useless comments with their spare time.
Old May 19, 2008 | 10:06 PM
Mugatu's Avatar
not really, i just hate when noobs are too lazy to search a topic that's been discussed to death.
cliffkemp
Dec 24, 2024 10:48 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Patricia Odell
SE RX-8 Forum
12
Nov 14, 2016 02:40 AM
Digitz0070
Oct 7, 2015 12:43 PM
