Outside Tire Wear
Old May 10, 2008 | 05:52 PM
Gauge's Avatar
Not Jeff Gordon
Outside Tire Wear
I have just noticed some tire wear on both front and back tires of my car, their new tires about 4 months old I guess. The tires on back are 255/35/19 fronts are 225/45/19 . Its mostly on the rear, was wondering if it could be camber . I would post a pic but Im at work. Just looking for some clues what it could be...all the posts Ive found have been inside wear..
Old May 10, 2008 | 09:27 PM
NotAPreppie's Avatar
What am I doing here?
Outside wear is usually excessive toe-in or (to a lesser degree) positive camber. Or you've been driving it hard without enough pressure and the tires have been rolling onto the shoulders.
Old May 10, 2008 | 10:55 PM
Gauge's Avatar
Not Jeff Gordon
tire pressure is fine i believe, looking at my tires from behind they kinda slant like
\ / inward/outward w/e way u look at it lol . btw I live around nothing but curvy backroads, driving hard is not an option
Old May 10, 2008 | 11:17 PM
Geforce07's Avatar
'04 Ti Gry MT > All
Initial D!
Old May 10, 2008 | 11:38 PM
Juice's Avatar
I made some poos
If you look at it from the back and the tops of the tires extend outward more than the bottoms it is a sign of too much positive camber. They should slant in so when you look at your car from the rear it should look like this, /\. Of course it isn't that excessive but you get the idea.
My advice is to get it checked out at a local alignment shop. It should cost about 80-100 dollars to get a full 4 wheel alignment and get it back to stock specs.
Old May 11, 2008 | 01:17 AM
Gauge's Avatar
Not Jeff Gordon
Thanks...except for the money part lol
Old May 11, 2008 | 01:24 AM
You really should get an alignment when you get new tires......You can wreck a new set of rubber really fast with an unaligned car
Hunterkelley24
Jun 14, 2022 08:32 AM
Michael Bryant
Oct 12, 2015 03:07 PM
Oct 3, 2015 09:51 AM
duworm
Oct 1, 2015 04:57 PM
