Front sway bar failures?
Old May 8, 2008 | 07:21 AM
tom28734's Avatar
I have OEM RX8 sways on my MX5, and they do exactly what I wanted. They transform the MX5, completely removing the excessive roll!
A miata.net user in Greece reported a failure of the aluminum ring that keeps the front bar in position resulting in damage to the shock. The ring slid away from the bushing allowing the bar to move.
I searched and found no reports of this problem here, but felt that I should ask in case my search text missed the mark.
I found my bars on your classifieds last year - Thanks, RX8club!
Old May 8, 2008 | 08:35 AM
invasion08's Avatar
I never heard of front sway bar failure. I do however heard of front endlink failure. Maybe the endlinks were not strong enough to handle the rx8 sway bar on your miata.
Old May 8, 2008 | 08:44 AM
Spinning Sushi's Avatar
I <3 Sushi
That's what I was thinking, try using the RX-8 endlinks.
Old May 8, 2008 | 01:02 PM
tom28734's Avatar
End Links?
Thanks for the suggestion, guys, but the end links are identical. Many of us use the RX8 endlinks anyway. The aluminum sleeve next to the bushing slipped.
Old May 8, 2008 | 01:07 PM
eviltwinkie's Avatar
Your talking about the bracket that holds the sway bushing and sway to the chassis...
I had the progress technology one snap on me a little while ago...
They DO break, especially if you increase the stiffness of the bar and the bracket is OEM.
Old May 8, 2008 | 02:17 PM
invasion08's Avatar
The miata guys should look at racing beats anti sway bars. They come with all the upgrades componets you need.
Old May 8, 2008 | 02:46 PM
ULLLOSE's Avatar
05-08 SCCA BS Natl Champ
I took my stock bar off years ago and never noticed it, but in fact I had the same thing happen. When I picked up another bar to try earlier this year I compared it to the stock bar just to make sure it was bent correctly. When I lined them up I thought the new bar was off, but it turned out that one of the stock swaybar stops had moved.
It is easy enough to move back, so easy in fact I can see how it moved. I think the best option is to remove the stock stops, or supplement them from behind, with a more durable set: http://www.hrpworld.com/index.cfm?fo...action=product
Old May 8, 2008 | 03:04 PM
tom28734's Avatar
Thank you for the reply and the excellent link.
Old May 8, 2008 | 03:23 PM
SouthFL's Avatar
Excellent info.
RXFEVER
Aug 29, 2018 10:14 AM
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
RXFEVER
Sep 11, 2016 02:51 PM
