Trying to separate the stock catback exhaust pipe from the canisters
Old May 4, 2008 | 09:04 PM
poweredbyplaav's Avatar
i recently installed the sp2 exhaust, and im trying to fit the stock catback in my storage. im trying to separate the catback pipe from the cannisters, but no luck. it seems as though they are held together by a U shaped metal screw. i was able to take the U shaped screw off, but the pipes are still connected.
anyone succeed in separating this?
Old May 5, 2008 | 01:32 AM
Astral's Avatar
Purveyor of fine bass
No, and I had only 5K on the exhaust. Had to saw it off. It rusts on real quick.
Old May 5, 2008 | 06:15 PM
Mazmart's Avatar
It's crimped after they're joined. They aren't meant to come apart unfortunately.
Paul.
Old May 5, 2008 | 06:44 PM
Snakebite202's Avatar
IT Guy
Metal saw and pair of gogles - works wonders.
Old May 5, 2008 | 06:46 PM
yale02's Avatar
Still plays with cars
I just recently did it by spraying WD40 into the joint and having a friend help twist and pull it off. It was on really tight but it did eventually separate.
Good luck!
Old May 6, 2008 | 12:55 AM
nice. ill give it a shot with a lotta wd40!
Old May 6, 2008 | 09:38 PM
Mazda specifically says never take it apart because it will never seal again per Mazmart's comments, if you do then a new pipe is required
Old May 6, 2008 | 10:27 PM
lilring's Avatar
Finally a MT
i had to do the same thing when i installed my borla... i just took a plasma cutter and cut that off... which is always fun to do.
Old May 7, 2008 | 01:14 AM
well cutting it defeats the purpose of separating them, since the main reason why im trying to fit it in my storage is to be able to use one day if i ever needed to.
Old May 7, 2008 | 01:29 AM
turborx8's Avatar
Boost 4 Life
Any shop can weld them back together.
Old May 7, 2008 | 09:38 AM
lilring's Avatar
Finally a MT
anyone with a welder will do it for you... it doesnt take long at all to do and wont cost much either
SupraG
Sep 21, 2015 12:09 AM
yapakanichi
Aug 25, 2015 01:24 PM
Juansito
Aug 12, 2015 05:32 PM
N0P1st0ns
Jul 30, 2015 09:45 AM
