I know its not an 8 but its my first car....
Old Apr 25, 2008 | 06:24 PM
mikeng714's Avatar
change your batteries or check your starter
Old Apr 25, 2008 | 07:36 PM
R888's Avatar
WedsSport Member
If you don't have money to fix your old car, how do you pay the difference for the 8.
I would not recommend you fix it yourself, let the mechanic do it for you.
Old Apr 28, 2008 | 02:15 PM
cyrollan's Avatar
Power relay
Could be the power relay. That happens with Hondas... the sunlight shines on the rea where the relay is... heats it up. Not sure about the Sentras, but the symptoms sound familiar!
Later
Old Apr 28, 2008 | 10:50 PM
Haze's Avatar
First thing to do is put a voltmeter on the battery to make sure that it is kicking out enough volts when you turn the key. Second check and make sure that the battery terminals are clean with no corrosion, then disconnect the battery from the electrical system and clean all of the terminals on the starter. Reattach the battery and see if it is better.
Assuming that the above does nothing, then it sounds like a bad starter to me. It's easy to put in, but they are expensive new. Try getting one from a junk yard. Only thing to know in installing a starter is to make absolutely sure that you have removed the battery first.
I'm not really buying the relay theory, but it is possible. In Nissans, there is usually a realy from another system, like cruise control if you have it, that can be switched into the starter relay. If the relay is bad then switching in a known good should be an easy way to check that. Best of luck.
Old Apr 28, 2008 | 11:39 PM
In the old days it would be your starter.
Old Apr 28, 2008 | 11:58 PM
hakuna matata!
lol pistons
Old Apr 29, 2008 | 12:00 AM
Battery & Starter.
Zelse
16
May 16, 2012 05:39 PM
flip
RX-8 Multimedia/Photo Gallery
18
Sep 23, 2008 02:54 AM
DA GREEKHITMAN
Jul 8, 2008 12:26 PM
davester
Far East/Asia
Mar 17, 2008 09:24 AM
