NW RX-8 Forum Serving WA, OR, ID, AK
ECU Management
Old Apr 13, 2008 | 08:00 PM
J.Cab's Avatar
1st RX8 BNR Turbo Owner..
ECU Management
Since we are kind of limited to who can tune an rx8 up here in northern washington state, I figured I would ask what ECU you guys would recommend? I see quite a bit of people switching over to the COBB Accessport, but there is still the greddy, etc.
Old Apr 13, 2008 | 11:59 PM
shaunv74's Avatar
Power!!
Cobb is the only one that can change the car ECU.
The Greddy and Int-x are separate piggyback units. If you buy the Cobb fom MazdaManiac he will support you by building maps for you and has many NA and turbo combinations already set up.
Old Apr 14, 2008 | 06:52 AM
heyarnold69's Avatar
Rotary wanabee
efidude also works ............ but if you go with options and ease of use .... cobb wins ..
efi dude -- 300 ish
cobb -- 800 ish i believe
Personally im saving up for the cobb
also I hear mm's maps are nice............ tuning usually costs around 300- 500 dollars per map
Old Apr 14, 2008 | 10:00 AM
Nemesis8's Avatar
Bigus Rotus
Whatever you do, save your money for a flash tuner. The OE pcm is the best out there. No more E-Mangled cars!
Old Apr 14, 2008 | 11:18 AM
kristopher_d's Avatar
Drive Master
+1 for reflashing stock ecu
+100 for cobb.
Just plugged mine in yesterday and it's so easy it's not funny. A bit of velcro, a relocated ODBII plug, and I'll be golden... well... at least silver... maybe bronze.
Old Apr 14, 2008 | 11:23 AM
shaunv74's Avatar
Power!!
Old Apr 14, 2008 | 12:16 PM
J.Cab's Avatar
now is MM the only person that can really tune the COBB and have it maintain its reliability? It would be great if someone could tune up here in northern washington.
Old Apr 14, 2008 | 01:58 PM
Drive Master
If you can find someone who knows the rotary (and the RX8 in particular) and has the necessary licenses and software to work with your chosen EMS, great. MM is a good resource because he has so many pre-existing maps available and includes what you need for a near custom tune in the price of the AP. If you go the Cobb route, buy the unit from MM so you'll have something to work with when the package arrives. If you want to be more aggressive or do something else bizarre, you can then find someone local (maybe).
Old Apr 14, 2008 | 02:08 PM
mysql's Avatar
Doppelgänger
read the cobb discussion thread if you have questions on it. There are a few misleading/incorrect posts in this thread already.
Old Apr 14, 2008 | 04:34 PM
Drive Master
Semantically speaking, for there to have been "a few misleading/incorrect posts" one would have to assume that every post save those from the OP was misleading/incorrect.
Okay, maybe my claim of being similar to a semi-precious metal is bit far-fetched, but...
The scarcity of re-flash options was correted by a subsequent post.
EFIDude certainly has lots of flexibility.
Everything else is opinion, and where possible supported by facts (or at least fact-lets).
Old Apr 14, 2008 | 05:05 PM
mysql's Avatar
Doppelgänger
You're only adding to it. Few just means a couple. Given that there were 8 posts, claiming that few meant all 7 posts (not including OP) were incorrect shows a gross misunderstanding of the word on your part.
For example:
It's not.
They don't.
Of course not.
We have yet to see that proven.
Old Apr 14, 2008 | 06:10 PM
Drive Master
Are you being pedantic or playful, sorry. Lack of smilies or other cues (on my part as well) make it tough to tell.
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
yurcivicsux
192
Sep 12, 2017 10:54 PM
Jelliott5384
Oct 26, 2016 05:15 PM
stickmantijuana
Rotary Swaps
11
Sep 24, 2015 12:47 AM
stickmantijuana
Non-Rotary Swaps
Sep 19, 2015 03:15 PM
