can you turn off check engine light by unplugging the battery for an hour?
Old Apr 9, 2008 | 02:38 PM
rx8m04's Avatar
does anyone know if you can turn off the check engine light by unplugging the battery for an hour? i had a spark plug issue ......so i changed those but now i just want to get that enginge light off. thanks!
Old Apr 13, 2008 | 05:37 PM
GuyWithRx8's Avatar
Low compression
It will go away, but if there is still a problem it will come back eventually
Old Apr 13, 2008 | 05:42 PM
DarkBrew's Avatar
Extraordinary Engineering
Yes
Or find someone with an ODB-II scanner, read the code and clear the light.
At least then you'll know what's going on.
Old Apr 14, 2008 | 12:54 AM
tiltmode43's Avatar
OMGITM!
Generally not a good idea but I've been guilty of doing it once or twice for my catless CEL for particular reasons :O
Old Apr 14, 2008 | 07:32 AM
rx8m04's Avatar
thanks every one!
Old Apr 14, 2008 | 07:59 AM
imput1234's Avatar
I ♥ Drifting!!!
reset it, go to autozone get them to scan it
Old Apr 14, 2008 | 10:00 AM
Spinning Sushi's Avatar
I <3 Sushi
You made two threads with the same title and asked the exact same question...
https://www.rx8club.com/series-i-tech-garage-22/can-you-turn-off-check-engine-light-unplugging-battery-hour-142877/
Old Apr 14, 2008 | 10:02 AM
I <3 Sushi
Oh, I forgot to mention that you also posted in the wrong section of the forum....
vapor2
Nov 3, 2020 03:38 PM
akagc
Aug 11, 2015 07:07 PM
Ajmurphy85
Jul 30, 2015 07:51 AM
marc2820
Jul 26, 2015 10:47 PM
netrovers
Jul 20, 2015 03:32 AM
