Carbon Fiber care
Old Apr 9, 2008 | 01:07 PM
samskillz's Avatar
Carbon Fiber care
Ive been searching threads about waxing and clay baring, How to and what to use...What should i do differently on my hood, is it safe to use turtle ice wax on it?
Old Apr 9, 2008 | 06:29 PM
delhi's Avatar
Grand Chancellor
Dunno. I never bothered cleaning the CF driveshaft...
Old Apr 9, 2008 | 09:03 PM
636's Avatar
636
Rice Police
Is there a reason turtle wax ice would not work? Id rather use a pastey type wax though , easier to see where u left off and stuff.
Old Apr 9, 2008 | 09:17 PM
ice wax is crap dont waste your time.. just use a good wax..and occaisionally clay bar it thats all you need.
Old Apr 10, 2008 | 11:35 AM
dozer's Avatar
on his 3rd rx8
meguiars nxt
Old Apr 10, 2008 | 09:51 PM
joebennz's Avatar
the swirlinator
Originally Posted by dozer
meguiars nxt
nxt 2.0 is the shizzle
Old Apr 11, 2008 | 11:49 PM
use nxt followed by meguiars carnuba..i forgot the # though.. hah
Old Apr 21, 2008 | 12:46 PM
joebennz's Avatar
the swirlinator
either # 26 high tech yellow wax or
gold class works fantastic
Old Apr 29, 2008 | 02:23 PM
LiL BenNy's Avatar
Bubblicious? DEF.
typically i use to wash it and then use a quick detailer about 1-2 a week.. and wax atleast 1 a month worked well... untill my car sat at the shop for 5 months and all the cf went to hell..
Old May 13, 2008 | 10:39 PM
rotoryman8's Avatar
RoToRyMaN8
http://www.autopia-carcare.com/inf-perfect.html
good guide
Old May 14, 2008 | 06:11 AM
altspace's Avatar
Eccentric Shafting
^Bing bing bing! If your hood is clear coated, treat it like you would with the entire car. But, if your cars stays in the sun all the time and no cover, then treat it even more so.
Old Jan 18, 2009 | 04:39 AM
krijpipudht's Avatar
Hi guys! My name is Tony.
From: San Francisco Bay Area 94542, USA. Earth. Solar System. Milky Way
I just moved to new house and now my 8 with CF will get sunlight from sun rise till around 11am.
Any car wax has UV protection?
Old Jan 18, 2009 | 05:16 AM
Flashwing's Avatar
3-wheeler
The best solution for anything carbon fiber is having 3m clearbra layered on top of it. It prevents the clear coat from fading from the sun and should the hood crack it will contain the cracks.
Prolonged exposure to sunlight will cause the gel coat to fade and yellow. At some point it will have to be sanded and either reapplied or painted.
The 3m material can be costy to have applied but it beats having to repaint the hood.
Old Jan 18, 2009 | 10:37 AM
darnellm's Avatar
I had my CF hood clear coated with a high solids clear coat.
The gel coat does not hold up well as you know
Old Jan 18, 2009 | 02:02 PM
Fathead_03's Avatar
VRX8
I also recommend clear coating CF hoods, trunks, etc. The factory coating on CF parts doesnt stand up well to the elements. Even the name brand parts will take a beating after a while. Getting your CF clear coated is a good investment, as it will keep your CF looking alot better, no fade, and you can treat it like a normal body panel. Especially helps with rock chips.
I used to work at a custom/restoration shop and cleared the CF parts on any car we built. Its like preventative maintenance.
Old Jan 22, 2009 | 06:39 AM
Quick question.
Will PlasticX work with minor swirl marks on CF clear coat?
or just wax CF like you wax your car.
Old Jan 22, 2009 | 05:55 PM
altspace's Avatar
Eccentric Shafting
If you are looking to try and do a quicky removal, then it's Sctrach-X you want. It's not perfect, but has some swirl removal capabilites. What you really want is to do a full PC job on it with proper products. Man I can't wait to break out my PC once winter is over.
Old Aug 19, 2009 | 02:15 PM
xtreme velocity's Avatar
Only wish I owned a RX-8
I bought this car back in December. And the guy who had it before did not take very good care of it. So. My question is that if my CF hood is fading is it just screwed? Or can it be saved? It looks brand new when wet. But when it drys it looks like crap.
Old Aug 19, 2009 | 02:18 PM
ac3mastuh's Avatar
Got Ings?
the clear coat is in bad shape, you can use either a rubbing compound and see where that gets you, worst case scenario, you can just wetsand the hood with 1000 grit sandpaper and take it to get re'cleared and it should look just like new
Old Aug 19, 2009 | 02:20 PM
Well its a black car. And the CF looks good. But kinda hard to tell its a CF with the car being black. Would I be better off getting a diffrent style hood and painting it black. Or try and save this one?
Old Aug 19, 2009 | 02:21 PM
ac3mastuh's Avatar
Got Ings?
id try to save it first, and if it doesnt work, then just paint the hood you have.
Old Aug 19, 2009 | 02:41 PM
Ill try that. What rubbing compund should I use?
Old Aug 19, 2009 | 02:47 PM
ac3mastuh's Avatar
Got Ings?
3M makes a really good quality one, you should be able to get it at a paint supply store or even your local home depot
Old Aug 19, 2009 | 03:09 PM
RawrX8's Avatar
Grocery Getter
If you have exposed carbon (only laminated with ester resins since expoxy will insta brown) you can use.
Or just use it in general. Nice stuff found at any hardware store.
Old Aug 19, 2009 | 03:28 PM
cidvicious831's Avatar
how long do cf hoods usually last?
