New fuel injectors
Old Apr 1, 2008 | 07:13 PM
RXgrayspeed1's Avatar
New fuel injectors
does putting new fuel injectors do anything to your car like if i out 550cc injectors in it will it help with perforamce?
Old Apr 1, 2008 | 07:19 PM
mysql's Avatar
Doppelgänger
you don't need new injectors unless you're at 80% of the existing ones. which means you need to be close to 300 whp.
your stock injectors have more than 1/3rd more capacity than a stock car can make use of. upgrading to larger injectors isn't going to do squat for you.
Old Apr 1, 2008 | 07:21 PM
On the stock ECU...it won't run... You could make them run with a reflash........BUT
With NA..you don't need them..you have more than enough fuel
Turbo...you would need an upgrade for over about 300HP
Old Apr 2, 2008 | 01:27 AM
tiltmode43's Avatar
OMGITM!
If you're over 300hp (aka fi) you will need... Wait, was that already stated?
Hunterkelley24
Jun 14, 2022 08:32 AM
urbanvoodoo
Sep 30, 2015 12:41 AM
RotaryMachineRx
Sep 29, 2015 10:26 PM
DeltaJ802
Sep 29, 2015 01:20 PM
Jb4ker96
Sep 27, 2015 10:06 PM
