Stock clutch question.
Old Mar 25, 2008 | 02:33 PM
SoloMazda8's Avatar
Leisy
Was wondering if the stock clutch needs to be replaced at a certain miles. I just hit 60k and for the past maybe 2-3k the clutch feels loose, like it grabs further out more and more, any input is great, thanks.
Old Mar 25, 2008 | 02:36 PM
When was the last time you bleed/flush your Brake system ?
and it might be bad clutch, but U should check the Clutch pedal to see if its still within spec.
Old Mar 26, 2008 | 09:50 PM
SoloMazda8's Avatar
Leisy
I've don't think i have ever bleed/flush the system.
Old Mar 26, 2008 | 10:09 PM
maybe u should do it then.
Old Mar 27, 2008 | 07:21 AM
expo1's Avatar
He's as bad as Can
Miles is not a good thing to go by because driving styles vary. I changed mine at 86,000 as an excuse to upgrade and the OEM still had life left on it. I do mostly highway driving and I have never done a clutch drop.
WranglerFan
May 31, 2022 07:51 AM
yankeepicker
Sep 11, 2015 05:42 PM
GARCIAC951
Sep 10, 2015 07:17 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
