02 sensor replacement
Old Mar 22, 2008 | 01:58 AM
boonyloh's Avatar
Rotorhead
Just found a P00138 CEL code... might be electrical short or malfunction sensor located near the cat/exhaust.
Anyone has any Idea of a Replacement O2 sensor that is usable for a 6mt else then oem?
Found online there are quite a variation of NB O2 sensors.. my guess is the 4 wires ones will fit any ideas?
Old Mar 22, 2008 | 06:37 AM
Front O2 sensor cost about 240
Rear cost less, like 1/2 the price I think
Its a PAIN to replace the front O2 sensor ... Rear is a piece of cake.
Old Mar 23, 2008 | 09:11 AM
boonyloh's Avatar
Rotorhead
so any 4 wired O2 sensor will work?
Old Mar 23, 2008 | 06:20 PM
Jax_RX8's Avatar
Got Another Rotary
Sparkplugs.com has replacement O2 sensors for $142 each (front and rear are the same, but you may need both). Good place for plugs too.
BTW - you need to look them up as a 2004 model year as they do not list them for newer model years for some strange reason - they are all the same.
http://www.sparkplugs.com/
Old Mar 23, 2008 | 10:03 PM
dothackRAVE's Avatar
<3 Rotary
Quick question: How many O2 sensors are there in total?
Old Mar 23, 2008 | 10:31 PM
2 in total, Front and Rear.
The front is located B4 the cat converter, on top of the pipe.
the rear is by the Cat converter (more like after), on the side.
Old Mar 24, 2008 | 12:17 PM
O'Renesis's Avatar
Not any 4 wire O2 sensor will work as regards throwing a CEL, but may work OK otherwise.
According to the workshop manual the front O2 sensor heater element resistance must be between 2.16 ohms and 2.9 ohms. If the resistance is outside this you will get a CEL.
Old Mar 24, 2008 | 04:06 PM
Just get some stock one, or OE replacement.
Replace them every 50K miles. Like I said I just replaced my front and Im around 39.3 K miles. not like I have a CEL or anything, They took the tranny down to replace the clutch, its all out, so why not replace it ?
drebbrnator
Dec 27, 2018 07:02 PM
MANIACman
Nov 11, 2015 10:58 PM
RXeckless
Aug 16, 2015 12:52 PM
RXeckless
Aug 16, 2015 12:51 PM
