Another Car won't Start Thread (Yes I searched!)
Old Mar 21, 2008 | 04:58 PM
Jeison's Avatar
Another dumb problem regarding a non starting car that's not related to flooding from a quick cold start.
When I drive the RX-8 and it's totally warm (needle @ 1/2 way on the dial), and I turn the car off, it will not turn on again until the car has cooled some, it cranks and gets to the threshold of starting(7-8 hundred RPM) but won't actually turn over (starts w/ a boost though)
Quick Recap of my car (bought used):
04 MT
63,000 km's
According to Mazda Canada all TSB's done
I've actually have less issues with cold starts then I do with this, but I always let the engine run for @ least 15 mins before shutting off
Edit: this should probably be in the issues forum, could someone move this??
Old Mar 21, 2008 | 05:51 PM
Georgia8er's Avatar
Sounds like your battery may be weak, since it's not turning over fast enough and a boost does it just fine. And it's an 04, has the battery ever been replaced?
Old Mar 22, 2008 | 11:41 AM
EDZRIDE's Avatar
2005 White GT
I have experienced the same problem. Turns out the starter motor was revised for the '04's and early build '05's. Here's the TSB.
http://www.finishlineperformance.com...48-06-1691.pdf
Old Mar 28, 2008 | 07:59 AM
Edwin Cowey's Avatar
Same prob.
Yes,I too have been having this issue with an 04 8. No problem with cold starts, just the warm re-starts like after stopping for more beer. I actually had to be towed to a dealer last week because it wouldn't start after stopping for gas. It killed the battery, but I am still having starting issues even with new battery.
Edwin
Old Mar 28, 2008 | 08:06 AM
This TSB seems to be for the cold start problem, not the warm start issue I have noted. I will be bringing a copy of this TSB when I have my snow tires off. Since it is snowing heavily here in VT, it may be another month before I can do that!
Edwin
Old Mar 28, 2008 | 10:55 AM
savedsol's Avatar
Carbonormous
They updated the starter. If you don't have it go get it done. I'd get the new flash and cleaning procedure done. No start when hot was the beginning of the end for engine #1 for me.
Wantingtoknow
Dec 15, 2016 02:25 PM
Dokuji
Nov 1, 2016 02:51 PM
Davey's RX-8
Jul 28, 2015 12:13 PM
harithac
Jul 25, 2015 04:21 PM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
