Rotora Front/Rear BBK
Old Mar 18, 2008 | 09:43 PM
acc03rd's Avatar
For sale is a Front/Rear Rotora Big brake kit off my IS...I know this won't directly bolt onto a rx8 BUT you can get a bracket made to fit onto it...or maybe you can order one from Rotora and then bolt them onto your car...i dont know exactly how this is done BUT ITS POSSIBLE...i'm selling the brakes for cheap so either way it won't cost you much to have this bbk setup on your car. I dont really have the time to call up and ask...but if your interested then feel free to call these numbers for more info to fit them onto your car...
Albert @ TWS - (909) 468-1311 - you can ask him how much to make a bracket to fit onto your rx8.
or you can Call Rotora direct and ask if its possible to order a caliper bracket for the rx8 and change it.
Specs...
Front 6 Piston Caliper / 2-Piece 355x32 Rotor
Rear 4 Piston Caliper / 2-Piece 355x32 Rotor
Used for about 10k Miles...still in GREAT Conditon.
Retail...4850
Take them for only 2800
Old Mar 18, 2008 | 09:51 PM
Texak's Avatar
Don't Tase Me Bro!
I don't think the 8 can use any aftermarket calipers on the rears, without disabling the hand brake. Anyone know for sure?
Texak
Old Mar 18, 2008 | 11:58 PM
Batman&TheBatmobile's Avatar
♥'s racing beat
i dont think ive ever seen it done. would look hot as **** tho
Old Mar 19, 2008 | 07:07 AM
rx8spiritR's Avatar
----Got Rice?----
Texak
yes it can be done and I've seen a few JDM tuner done it to the rx8. Just like the NSX, the rx8 use cable for the hand brake, so an aftermarket caliper will disable the hand brake, so what they do is they'll put a big caliper on along with a small caliper for hand brake, usually the stock one but in some case, brake company have smaller hand brake calipers, Stoptech has one. Unlike the 350z,evo and sti, they used brake drum for the rear, so they'll have no problem getting their caliper upgrade.
Old Mar 19, 2008 | 07:09 AM
rx8spiritR's Avatar
----Got Rice?----
oh and those rotors won't work on an rx8
Old Mar 19, 2008 | 05:12 PM
acc03rd's Avatar
rotors should work..there the same bolt pattern...5x114. if you go to someone who knows whats hes doing he can get them to work...
im putting a big brake kit made for a Euro car on my car...diff bolt pattern on the rotor and he's still making them work.
Old Mar 19, 2008 | 05:25 PM
TopGear8's Avatar
mkuhnracing.com
Car looks nice, Good luck with the sale.
Old Mar 19, 2008 | 08:58 PM
c41250n's Avatar
yea it will work! but you just need hella custom work!
someone up here did a sr20 swap too! everything is possible! you can even turn your 8 into a convertible if you like to!
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
J2daG1990
Series II Wheels, Tires, Brakes & Suspension
Sep 24, 2015 09:20 AM
PUR NRG
17
Feb 4, 2005 08:32 PM
